Tree Prop
25,367
25
Published
Introduction: Tree Prop
About: I love puppets and making Food! visit my website, andruppets.com
This is a great way to have a tree in your own home without the mess! Things you will need, Expanding foam Chicken wire Worsen stake News paper ( I found a roll of packaging paper that worked well) Tan spray paint Brown paint Black paint Paint brushes Fake tree branches Wire Hula hoop Lets get started!
Step 1: The Trunk
F!or the trunk we first need to have a frame. I made my frame from a sodden stake that I stapled heavy duty chicken wire to. Then I got my newspaper and duct taped it around the whole trunk so no Erie was showing. Make sure the newspaper doesn't sag. Now draw guidelines of where you want the bark strips to be. Now with you'd expanding foam spray it on your structure following your guidelines. With a spray bottle spray with water. Then let dry until firm.*when using expanding foam wear gloves* Now the trunk is dry spray with the tan spray paint and let dry. With a paint brush paint black in the gaps of the trunk and where ever else you think it needs to be. Now let your creative side take roll and do detailing with brown paint. Once dry you have your trunk.
Step 2: The Branches
Now time for the top of the tree. Stab 4 pieces of wire onto the top of the trunk and curl to they won't come out. Now connect the other side of the wire to the hula hoop. With your tree branches zip tie the stems to the hulls hoop in different possessions (some up some down) once you're finished with that then your done! Congratulations! Thank you! -Andrew
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    2 Comments
    I got the leaves from Michaels craft store. No I didn't cut the hula hoop in half. You can either use a very small hula hoop or get two sizes of styro foam wreathe forms from a craft store. Put the big one near the top of the trunk and the small one above. Then you can just stick the leaves directly into that.
    Where did you get the leaves and did you cut the hula hoop in half? Trying to envision the top of the tree better. Thanks!
