Tree Safe
12,428
89
10
Posted
Introduction: Tree Safe
In this instructable I will be explaining how to make a tree safe from a coastal redwood. The coastal redwood tree works great for this because it has a thick bark but really any tree with a bark that is at least 2 inches thick will work.
The coastal redwood is an endangered species, but this shouldn't hurt the tree. This safe is outdoor and may not be watertight, so anything that is being stored inside should have a plastic bag around it.
Anyways, lets begin!
Step 1: Materials
The materials needed for this project are:
•One large, thick piece of bark (back must be flat)
•One smaller flat piece of bark
•White glue (gel variety)
•Pocket knife (or other carving utensil)
•Paperclip (unwound, cut in half, and bent at a right angle)
Step 2: Carve
Using the pocket knife carve out the center of the flat back side of the large piece of bark.
Step 3: Insert Paperclips
Next, take the paperclips and stick them into the walls of the carved indent that was made in step one. Make sure it doesn't puncture out the other side.
Step 4: Glue
Now add glue to the base of the paperclips and allow to dry.
Step 5: Apply Backing
Once the glue is dry, take the thin flat piece of bark and stick it through the paperclips so that the only thing visible are the two paperclips sticking out the back.
Step 6: Apply to Tree
Place any items in container and apply backing, now it is time to place it! Find a nearby tree and stick the paper clips into the bark then push until the safe is set into the tree.
Now step back and admire the perfectly camoed container! Enjoy!
If you enjoyed this instructable please take a moment and vote for it! The button is in the top right corner! :D
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    10 Comments
    thank you! be sure to vote! :P
    Tree cutting is vital piece of tree surgery Because when we cut any huge tree then you have take think about little tree for more points of interest log on to
    http://www.adelaidetreesurgery.com/service-tree-removal.php
    I like it but couldn't you use thin head nails instead of paper clips
    True, but the only problem is that the redwood bark is quite soft, so the back of the nail would puncture the other side
    I do not get it< what was done in here? Cut off a piece then attach it? Whre is the safe? or was it to save it? Please explain.
    the other piece of bark "thin and flat" was stuck to the fatter piece by the paperclips, creating a container.
    That would make a great geocache hiding place. The hint could be "on the tree". >:)
