3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Trekking Pole Tripod
Headed to Zion NP to do some backpacking in the Virgin Narrows and didn't want to lug a tripod around with me. Since there were two of us going (and 4 trekking poles), I figured I had enough poles for a last-minute tripod. Entire project done in the one hour before heading to the airport, including wandering the hardware store! I love living next door to Discount Builders!
---SUPPLIES---
2-6" Flexible Gas Conduit (about 3/4" in diameter)
2x 1/4-20x1" Hex Bolt
1/4-20 Long Nut
1/4-20 Washer
5-Minute Epoxy
Trekking Poles
---TOOLS---
Metal Saw (Sawzall or hacksaw)
Metal File
1/4-20 Tap/Drill Set
UPDATE: Just came across this design on the web, looks to be a bit sturdier though maybe 10x the weight. Either way, another option!
Step 1Prep Conduit
Prep Conduit
I was originally planning on using some sort of flexible copper piping, but found this gas conduit instead. Unfortunately the tube cost $13 since it was a full assembly . . . I doubt any place would sell this stuff any other way (except at a junkyard of course!)
Pretty easy step here, cut the conduit to size and file any rough edges that may remain. I used about 4-inches since I wanted to be able to bend the tripod 90-degrees for portrait shots. As a note, I found this length to be a bit long for super-stable shots, as the weight of the camera "bounced" if you weren't careful. If you're using a heavy camera definitely go shorter! To dampen this bouncing, you might find it useful to fill the conduit with something like sand . . . but that of course adds weight!
7 comments
Apr 28, 2010. 3:08 AMjustgettingstarted says:
What a great idea! I've been wanting to build a monopod out of one of my walking sticks and parts of your Instructable will make it finally happen. A small suggestion: Instead of cutting off a bolt's head, try using an Allen setscrew. They come in various lengths from a couple of threads long to a couple of inches. It can be difficult to cut off a bolt and then make the threads clean enough to be usable. Thanks again.
Oct 3, 2007. 6:31 AMEdM says:
I have a simpler and easier solution. Buy an inexpensive monopod, which telescopes down to about 18" for transport and is very light weight. The m-pod screws directly into the camera and forms the third leg of the triangle (so you only ever need your own 2 walking sticks). I cinch down my walking stick straps around the m-pod grip and give them a couple twists for a nice, firm hold. Since the m-pod usually needs to be vertical (unless it has a swivel head) you have to be careful as this makes a slightly less stable tripod (unless you tie weights to the walking sticks). However, aiming a heavy lens toward the walking sticks makes this more stable and is usually able to support it with no problem.
Sep 28, 2007. 5:36 PMchase.carlton says:
Nice instructable. Ozark Trail(super-cheap Wal-Mart brand)'s trekking pole's handle unscrews to reveal a 1/4-20 thread that you can use as a monopod.
Sep 27, 2007. 12:11 PMclievers says:
That's cool. A while back I was thinking it would be cool to just attach the tripod device (that connects to the camera) on top of a hiking pole, to give a monopod. It would be good for steady shots, but not "self" shots (it could fall over, lol). Not sure how I would go about that. But this is a good idea.
Sep 24, 2007. 10:57 AMnk2007 says:
Not a bad design, but i would be wary of puting anything other than that body and the kit lens on there, as anything heavier i would assume it would bend/break/droop. (i have an Xti with 70-200 2.8L) and that thing is heavy.
Sep 24, 2007. 4:39 AMJohn Smith says:
Nice project. We hiked in the narrows, and all around the park, too. Zion is definitely my favorite park.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:jeffkobi
