Step 3Install the TRI color LED with a 100 ohm resistor
iImage Information
This step may vary depending with the mod your are doing. I soldered a 100 OHM resistor inline with the + (the longer) lead on the 3 color led and since this is a USB mouse, connected the wires directly to the + and - connectors on the circuit board. I found that this peticular LED is sensitive to current requirments, to much resistance and all the colors won't light or cycle . Too little resistance an it will have a very short life !!. The measured voltage was aroung 5 vdc. Mount the LED in such a way that it will fit into the lens and give you the illumination effect you want.
