Tri-Shift Copter
Introduction: Tri-Shift Copter
This is the Tri Shift copter.
Using the spring loaded trainer switch on your Turnigy 9x transmitter, all the motors will pivot forward 45 degrees. Now with motors pivoted forward from switch and pressing forward on the stick, motors can be forward 90 degrees. Of course at 90 degrees forward the copter will drop but, will achieve maximum speed. So the the trainer switch can be thought of as a kind of turbo boost. A GoPro hangs underneath the nose and if you like to take level shots, just use the trainer switch instead of forward on the stick.
Print out extra pieces to bring with you to the field in case of a crash. Most pieces are held together by zipties and a bolt or two. So, instead of buying a store bought copter for hundreds of dollars and crashing it, so now it's broken. With the Shift, in case of a crash, just swap out the broken pieces with the extras. You can be up flying again within minutes.
These piece can also be used to build simple Tricopters and Quadcopters and now a HeliPlane.
The video, the Shift Copter is on a stand for filming. The parts for the stand are made of copter pieces also.
Notice the magnetic couplers on servos. I've stripped out a couple of metal geared servos from crashing. My dad and I came up with couplers for the servos using cylinder magnets.
Step 1: Building Arms
We'll begin the build with the two front arms and tail complete. Builds can be found here:
Right Arm
Left Arm
The pieces are free to download and print out on your printer and can be found here:
List of pieces to print out:
1) Body X2
2)GoPro Mount
3)Component Mount
4)Servo Mount X2
5)Pin Mount A X3
6)Pin Mount B X3
7)MagSplit A 0.5 X2
8)MagSplit B 0.5 X2
9)Foot X2
10)Motor Mount X6
11)90deg Tail Pin Left
12)90deg Tail Pin Right
13)Tail Pin Coupler 0.5
14)Servo Shoe 0.5
15)Body Servo Mount
16)Front Universal A X2
17)Front Universal B X2
18)MagSplit A LG 0.75
19)MagSplit B LG 0.75
20)Lower Tail Hinge X2
21)Top Tail Hinge X2
22)Rear Landing
23)Hinge Support
Step 2: Pulling Wires Through
Pull all the wires through Body piece 1 and press arms into place.
Press second number 1 Body piece on other side. Most pieces fit together in a clam shell style.
Step 3: GoPro Mount
Two bolts through the center of Body piece 1.
Piece 2 has three tabs on bottom that fit into the body piece 1. Three zipties through GoPro mount piece 2 and Body pieces 1.
Second picture is the bottom side of Shift.
Large zip ties
Bolt Set(4-40 x 1 1/4")
Step 4: Mounting Components
Pull the three sets of wires part and loosely zip them to their bars.
The Component Mount of electronics can be found here:
Component Mount
Place Component mount in perspective to picture and hookup same color wires to each other. Left ESC goes to left motor,etc..
Step 5: Securing Body
Cut the zipties holding wires to loosley to the bars.
Pull wires back toward the tail with the Component Mount. Ziptie through the center two square holes of Body, and around wires to hold them down/back.
So the battery can rest on piece 2 and wires, pull wires to the left side 90 degrees. Ziptie them together as in the second picture.
Place a ziptie between Body piece 1 and GoPro Mount 2 facing down.
Step 6: Securing Components
Four tabs on the bottom Component Mount 3, fit into holes on top of piece 2. Slip a Ziptie between controller board foam and top of Component Mount 3 facing up.
Connect the two zipties into the other and around ESCs(electronic speed controls). Zip down on each side securing Component Mount 3 to copter.
Step 7: Tying Up Wires
Using smaller 4" zipties, tie up the wiring as neatly as you can, it's a bit of an art.
Small Zipties
Step 8: Power Wire
The power harness connects the battery to the ESCs. It comes with four leg sets four a quadcopter. Don't cut the other leg or the small component power wire if there. In case you wish to use these same pieces to build a quad copter or Quad Shift! For a Quad Shift, instead of building the tail assembly, Build four front arms with two body sets and connect together. Build instructions for Quad Shift coming soon.. All the pieces are all ready there to download for the build.
Tie up power harness with battery plug at rear of Body 1.
Step 9: Rear Linkage
Print out piece Body Servo Mount 15, MagSplit A LG 0.75 18 and MagSplit B LG 0.75. Use the mounting kit included with your HS-645MG servo(rubber garments, inserts and screw), to mount servo onto piece 15.
You'll notice this servo is a little larger that the two front 225MG servos to move this larger tail assembly around. This means the coupler is larger, and needs 3/4" x 1/4" cylinder magnets. The magnets and couplers are actually an optional item. Your servos come with horns, I've just stripped out a couple of servo from crashing. The original bolt for servo isn't quite long enough and needs this new Servo Bolt.
How to assemble Universal Magnetic Copler(UMC)
Cut a two inch long piece of threaded rod. Thread the ball joint on one side and the link to the other.
Slip piece 15 onto the tail bar and then mount horn or coupler onto servo. Before mounting coupler, try to find center position of servo. Press the ball insert of the threaded rod onto the ball mounted on tail assembly. Slide piece 15 with servo along tail bar so the length of the linkage lines up. Ziptie piece 15 onto bar and attach linkage.
Threaded rod
Ball Linkage
Servo link
Servo Bolt
Step 10: Front Linkage
Front couplers use 1/2" x 1/4" cylinder magnets and again, are optional for saving the servo from a crash.
How to assemble Servo Linkage
Also, there extra pics above to explain coupler.
Step 11: Mounting GoPro
Cut four 1/4" wooden dowels 1" long and press them into Foot piece 9. Putting some 5min epoxy into the hole of piece 9 is a good idea.
This variation of the TriShift has a low profile and the GoPro is not in it's housing. Instead of clipping in underneath, it has a ziptie through piece two. The ziptie is going around the camera with two sided foam tape between.
Step 12: Extra Ideas and Pictures
If you wish to build the version that's in the beginning video, there are canopy mounts that can be made from the Filament2 Tricopter build.
Above is a couple of pics I like and a wiring schematic.
Step 13: Earlier Pics of the HeliPlane, the Real HeliPlane Is OUT!
The end result of these pieces or goal is for a downloadable HeliPlane. These same pieces currently released can build up Tricopters, QuadCopters, TriShift and QuadShift. Working to soon release the rest of the parts for the Heliplane above.
I've just purchased the domain name
When the rest of the pieces are ready to be released, will be
There should be a Tri and Quad version available.
Again pieces are free to download at Thingiverse if you have a printer.
Uploading pieces soon to a site that makes the pieces in different colors for purchase if you don't have a printer yet.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    In case you find anywhere to visit CopterBuild, it is now, thanks
    Cool tricopter. Can it fly?
    I've only flown it a few times. Here's a video of an earlier version
    one question what happens when it reaches 88 mph
    I thought the fire was from the battery exploding but, now that you mention it, I don't think it's back yet
    You can get the pieces to download from Thingiverse.
    And here's a list of parts I used to design the copter.
    Canopy(400 - 450 size)
    Brushless Motor X3
    ESC(electronic speed controller) X3
    18" Servo Extension
    Bolt Kit(4-40 x 1") X3
    Power wire extension X 4
    Power harness
    Velcro Sheets
    Small zip ties
    Large zip ties
    1/4" wooded Dowl
    Canopy Wire(0.062)
    Velcro strap
    There's more information at
    Thank you for the question, please don't hesitate if there's anything else.
    Very cool stuff. I'm intrigued by the heliplane design!
    Thanks! shouldn't be to long from now
