3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Trickle charging auto-switching LED helmet
I was inspired by calebjc's green helmet to build my own. I suspect the parts on mine were easier to come by (bike store and wherever solar powered yard lights are on sale). Another addition on mine is that closing the buckle switches on the helmet.
I needed to attach a block to the bottom front of my headlight to raise it, on first draft it lit right in front of the front tire unless I looked at the sky. I had checked the aim at home, but had not thought about how your head is held differently on a bike with relatively low handle bars.
Step 1Parts
- front and back bike lights
you may already have some, if so, use them. If you don't have any, choose some that appear "modifiable", e.g. screwed shut.
for simplicity, make sure both use the same number of batteries. Mine both use 2 "AA"s
- 4 solar panels (2 might do)
I got mine from cheap-o yard lights from a sale at Canadian Tire, ~3$ a pop. You might find some in the garbage, some people throw them out when the rechargeables die or after the get knocked over and break
- 1 diode
scavenged from the yard lights as well
- wires
I used some old phone wires, small guage will be fine
- double-sided tape
I also tried zip-ties but the tape seems to work better
- metal duct tape
not the plastic stuff... this will be used for circuits. Other thin metal sheets glued on would work too.
6 comments
Sep 7, 2008. 5:34 AMlaxboy7 says:
What helmet did you start with?
Aug 2, 2008. 3:04 AMpellepeloton says:
Is this a safe helmet I ask? Those added modifications stick out, and in the case of ,hopefully unlikely, accident or even hitting a tree with your helmet, it will get caught causing your head to twist? The primary purpose of any helmet is to protect the wearer from shocks and reduce the possible injury and any modification added into helmets may compromise these.
Jul 10, 2008. 3:19 PMcalebjc says:
Congrats! Glad I could help inspire.
Jun 6, 2008. 7:23 PMruzter says:
I can't believe I never thought of stealing the solar panels from lawn lights. I also like how you executed the strap switch. Not that I am biased or anything. Congrats on the prize!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:berserk
