Triple Single Rainbow Loom Bracelet
8,082
6
Posted in PlayToys
Introduction: Triple Single Rainbow Loom Bracelet
Triple Single Bracelet Rainbow Loom. :)
Step 1: Materials
The materials that you will need are:
1 loom board
1 hook
48 pcs. of loom rubber bands (12 A colored bands , 12 B colored rubber bands , 12 C colored rubber bands and 12 D colored rubber bands)
1 C-clip or S-clip
Step 2: Putting the Bands
First, you may want to make sure that the arrow is pointing away from you. Then, you will need to put the A colored bands on the left side of the loom. Go straight until you reach the end of the loom.
Step 3: Putting the Bands
Next, put the B colored bands on the middle. Then, go straight until you reach the end of the loom.
Step 4: Putting the Bands
You now need to put the C colored bands on the right side of the loom. Go straight until you reach the end of the loom.
Step 5: Adding Triangles
Now, get your D colored bands. That you'll use for putting the triangles. Skip the first 3 pegs on the loom then start putting triangles on the second 3 pegs. The point of the triangle must be pointing at you. Put triangles until you reach the end.
Step 6: Turn Your Loom Around
Turn your loom around so that the arrow is now pointing at you.
Step 7: Hooking the Bands
Now grab your hook. Pull the bottom band on the left side then put it on the peg where it belongs. Do the same with the middle and right side. Continue the pattern until you reach the end.
Step 8: Placing the Top Bands to the Middle
Pull the top band on the left side then put it on the middle. Also, pull the top band on the right side then put it in the middle.
Step 9: Pulling All the Bands in the Middle
Pull all the bands in the middle then put the c or s clip.
Step 10: Taking Off the Loom
You need to be careful on taking it off.
Step 11: Extensions
Put bands (according to the size of your hand) then put the last part of your bracelet on the last band. Then, start hooking. Then, your done.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
