Triple Your Tool Storage Space!
Introduction: Triple Your Tool Storage Space!
Maker Olympics Contest 2016
Runner Up in the
My workshop was a mess and I needed to organize the tool storage wall behind my work bench. I had too many tools for the space available and had to juggle tools from the front to the back of overloaded hooks.
Step 1: Add Tool Storage Doors
If the wall is too small, perhaps I could triple the space by adding doors. Tools could be stored on the front and back of the doors as well as the wall.
Step 2: Lay Out Your Tools
So I pulled all the tools off the wall, sorted the ones I wanted and used the most. Then using some scrap wood I tried different arrangements for each group of tools. The front of the door would hand hammers, the back saws and the wall would have the levels and straight edges. To have the strength to hold the tools I used 3/4" plywood. It also has the thickness to hold the pegs. Don't skimp on the hinges, with all the tools this door will be heavy so I used 3.5" house door hinges. Plus the pins are removable!
Step 3: Ready for Paint
So I put a top shelf with notches for each mallet, the hammers each received a hole with a Plexiglas notch to hold the head. The saws have wood pegs or screws to hang on, as do the levels and straight edges. Don't stop here with bare plywood, go ahead and put two coats of white paint on everything. It looks sharp and with brighten your shop.
Step 4: With Paint
So the paint is really worth the time. Makes it look nice.
Step 5: Pliers and Wrenches
The next area was a mess, jumbled drawers of wrenches and nut drivers in rotting pouches. So wood pegs for the wrenches, 2x2 wood strips for the nut drivers and a slot rack for the pliers.
Step 6: Files and Screw Drivers
More 2x2s to hold the screwdrivers. The lower rank has spacers behind it so the longer drivers have room. The white paint makes it easy to mark each location. It is so wonderful to know where to put each tool when I clean up! Four cabinet hinges to carry this load.
Step 7: Vice Grips
Vice Grips get their own door. Slots with a Plexiglas front makes it easy to see what is stored.
So I hope you can use this idea to make your shop just a little nicer!
Good Luck, Carl.
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Carl, you need a 4-foot pipe wrench, because it's a 4-foot pipe wrench.
    Keeping organized while still working on things has always been a challenge to me. I suppose it's partly due to not wanting to put things away until I finish a project and then not finishing the project right away. Having better storage would help with that. The one big problem I have had with custom storage is that as soon as I get it done then it get more tools and out grow the custome space. I have never found a solution for that.
    Hello Vyger:
    Peg Board is one option, but somewhat clumsy. I keep thinking!
    Thanks, Carl.
    One idea I had and am still kicking around is to make peg board pull out "shelves". Use some medium duty drawer glides but stand the drawer up on its side instead of laying flat and put the peg board in the middle so you can get to it from both sides. I also thought of using door hinges like what you did, somewhat like the displays of various paneling that you see in stores. But this idea might take up less space. With the drawer idea you could basically make a cabinet that the drawers pull out of, kind of like a sideways drawer unit. In computers its called rack mounting. You have rack unit that is a cabinet and the "blades" just slide in and out.
    However there are drawbacks to every idea. I can just see myself trying to open a jammed drawer because something fell off, went to the bottom and got stuck between the back of the drawer and the front. Yep, and I will wonder, "why did I ever decide to try this?" Probably will try it anyway.
    I have a bunch of mounting slides from servers that would make great drawer slides. They're designed to hold a server at full extension, so they should support drawers full of tools with no problem. If I line the drawers with rubber mats they shouldn't move around. hmmmmm
    Sounds interesting, but that is a lot of hardware $$, no? What do you think of a carousel instead? Peg board could be attached to both sides of a 2*2 frame and just mount half of a hinge on the top and bottom with a chunk of ready-rod running through them. Now make as many as you need and just flip them back and forth like looking through a pile of vinyl records or like when there is a poster display like this
    Hello Devine: Well except for time my cost was zero: Scrap plywood, handles and old door hinges from the bin and a few screws, also salvage. My problems with pegboard are keeping the pegs in place and the overall thickness. I have thought of the poster stand type display, but I'm happy with what I've done.
    Interesting ideas. Vertical tool doors or vertical pull out walls. Storage surface area increases dramatically, but I'm curious to know after a while if the tools tend to fall off accidently as you suggest. Shallow drawers is another option. That too increases the tool storage surface area. Many tools are no more than maybe an inch high, when laying in a drawer.
    Hi Gang:
    Just re-read the post about multiple swing doors like they display poster on. What If you did it in a corner of your shop. The hinge points would be on a diagonal across the corner. Then all the doors could swing 90 ° both ways before hitting.
    Outlining with a black permanent marker helps me identify whats missing . 3 sons all with their hands in the pie .
