loading
Step 3: Deface National Currency. or Use Washers.
Drill lots of holes: if you're not using washers, put holes through your spacers & nickels. You want the holes to be marginally larger than the threading you need to accomodate on your monopod. My threading was 1/4" and so I used my 1/4" drill bit and then wriggled the bit around once I'd drilled through.
Where to drill: If you followed my suggestions and have coins with buildings/eagles on the reverse, here's what I've found works.
On not-so-worn nickels, you might still see the architectural detail on the pediment (it's the triangle over the doorway). Center is approximately between the pediment and the top of the doorway. (But see below for drilling nickels off center)
On mint pennies, you can probably see Lincoln in the memorial. Nail him through the stomach. It probably doesn't matter much if you're off center on the pennies. As long as none stick out past the nickels when on the axle, you should be fine.
On the eagle quarter: er. uhm. uhhh. Crotch.
Hints & tips & Learn-From-My-Mistakes: (But you are quite welcome to make your own. And share! I might add to this list.)
-Mark the center of your coins and make a punch mark for easier drilling.
-Unless you've got some awesome ideas about clamping coins up/down/left/right/sideways, it's easier to drill them individually rather than as a stack. (The bit will tend to catch and then spin the coins rather than actually going through them.)
-Clamp the coin on some wood so you can drill through fully.
-I found that some coins will deform is enough clamping pressure is put unevenly on the edge, so I usually place a second coin beside the first and have the clamp hold both down.
-It might be better to have your nickels drilled slightly off center(!) If you tighten the sleeve around two centered nickels, the nickels will continue spinning on a center axle. If they're slightly skewed, the clamping might be enough to have them lock in place on the axle, assuming the holes are close enough to axle size. Drill a couple and play around during final pre-assembly.
@m1sterb0b<br/>its only illegal to deface currency if your intent is to defraud the government or others with the currency (ie pounding nickels into quarter sized slugs for the arcade machines) <br/>Make magazine confronted this just a short while ago <a rel="nofollow" href="http://cachefly.oreilly.com/make/halfdollarringcomic.pdf">Make: pdf</a> (see page 6)<br/>
thank you for that information. You brought that to my attention in a much nicer way than someone else did on a different section. I'll make sure to bookmark that link. I was always under the impression that it was illegal to deface coins or other currency unless in protest. not quite sure where I got the penny thing from either way. Anyways, Thank you.
Even though its illegal to deface any American currency greater than the penny, interesting concept.
Which law makes it legal to deface the penny?
&quot;Deface an American currency greater than the penny&quot; meaning, not including the penny. Im not sure when it was made legal to deface the penny but you can. All greater currencies are illegal to deface.<br/><br/>Section 331 of Title 18 of the United States code shows that its illegal.<br/><a rel="nofollow" href="http://www.usmint.gov/consumer/18USC331.cfm?flash=yes">http://www.usmint.gov/consumer/18USC331.cfm?flash=yes</a><br/><br/>again, im not sure where it says that its legal to deface the penny but IM pretty sure it is legal. (ill keep trying to find out)<br/>
Good use of readily available materials. Don't dip it in salt water or you might get electrocuted. ( <a href="https://www.instructables.com/id/E5227V5K1QEZBF8OQH/">https://www.instructables.com/id/E5227V5K1QEZBF8OQH/</a> )<br/>
About This Instructable
12,528views
7favorites
License:
More by ryzellon:Repairing a Nintendo DS Lite Make a sling (weapon) out of a grocery bag! (Plus two bonuses! "How not to use scissors" & "Replace bandaids with sports tape") Chainmail(le) Primer: Making Jewelry-Size Rings for Weaving Chainmail
Add instructable to:
