3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tripod Laptop Stand
Tripod Laptop Stand
Whenever I can, I like to tether my camera to my computer so I can see the shots on a real monitor. One night trying to do some star track shots I wanted to tether my camera, but had no where to put my computer... until now! I checked out this 'ible, but wanted something a little more engineered for my big, heavy laptop. Using mostly recycled materials, I made a platform which can be connected to a tripod mount (3/8ths in screw) or a camera mount (1/4 20 screw) and two clamps, one on either side, to hold the computer down.
Step 1Get your materials
Get your materials
For the base material I used some MDF type board from an old picture frame. Since it was less than a 1/4in thick I had to use multiple layers of this, adding up to about 3 square feet (this area will depend on the footprint of your laptop). I used a small 3in x 8in steel plate (less than 1/8th in thick) for the mounting plate and 4 small wood screws to attach it. For the clamps, I used two small knobs, some 1/4-20 threaded rod, 2 1/4-20 nuts, and 4in of shower door framing (for the clamp frame). A thin piece of foam protects the computer from the clamp. The clamps are connected to the base of the stand with two 1/4-20 tee nuts. Finally, a short piece of 1/4-20 threaded rod and short piece of 3/8th in threaded rod are used to store the two mounting wing nuts, one 1/4-20 wing nut for the standard camera mount and a 3/8th in wing nut for tripod mounts. Just to avoid any confusion, let me clarify that most tripods use the 1/4-20 standard and connect directly into a camera. However, for some tripods that you can change the head on, a 3/8ths in thread is used to connect the head to the tripod base.
Heres the summary of items to get-
  1. Baseboard
  2. steel mounting plate
  3. 4 small wood screws to attach steel plate
  4. 2 knobs
  5. threaded 1/4-20 rod (or just hack a long bolt)- about 4in long
  6. 2 1/4 20 nuts
  7. 3/8ths in threaded rod (or just hack part of a bolt- about 1 in long
  8. Some U shaped extruded aluminium for the clamp frame ( size will depend on laptop thickness
  9. A little bit of thin foam to pad the clamp
The tools (and adhesives) that I used were
  1. Drill and a set of bits (up to 1/2in) for metal and wood
  2. 1 1/2in and 1 1/4in hole saws
  3. Angle grinder (for metal)
  4. Clamps (the more the better)
  5. Wood glue
  6. Epoxy
2 comments
Jan 27, 2012. 5:55 AMyellowcatt says:
That does look useful.
If you have a tripod with a quick release mount then you could machine a replica mount to be permanently and securely fixed to the baseboard. That would make for easier assembly.
Another thought - if the laptop is going to be clamped to a foam mat it may be worth having some ventilation holes in the baseboard and mat that match up with those in the laptop.
Jan 22, 2012. 2:11 PMmikeasaurus says:
"Thanks to mikeasaurus for his version, and I hope the 'ibles community keeps on improving and modding this idea!"
Me too!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:andrewaxley(Andrew Axley)
