Tripod for Camera - Tripode para Camara
Tripod for camera, if you have a camera and want to take good pictures in which you can be in the picture, a good solution is to ask that someone take the picture or you can make a robot that you take the picture, in my case I made a tripod who held the camera, this is made of wood by the facility and the incursion of the hinges, but if you have other more material at hand, you can do it and cover it with black tape or paint to improve its presentation. It's great for taking those photos timer has very good stability and reaches the average height of three feet!, So get to work
Spanish - Español
Trípode para la cámara, si tiene una cámara y quiere tomar buenas fotografías en las que puede salir enellas, una buena solución es pedir que alguien tome la foto o se puede hacer un robot que tome la fotografía, en mi caso hice un trípode que sostenía la cámara, esta está hecha de madera por la facilidad y la incursión de las bisagras, pero si tiene otros materiales a la mano, usted puede hacerlo y se cubre con cinta adhesiva color negro o pintura para mejorar su presentación . Es genial para tomar esas fotos con temporizador tiene muy buena estabilidad y llega a la altura promedio de los tres pies!, Así que manos a la Obra!!
Step 1Tools and Components - Herramientas y Componentes
We Need - Que necesitas!!
1. Wood. For each foot: 2cm * 2cm * 96cm
How to make, look and found 3-wood waste Triplex laminate (wood) 9mm almost 2 meters, as she was very thin then cut in half and glue the six parties, it gave me 3 parts of 2 cm * 2cm * 96 cm, which would be three feet. You can also do other material PVC tubes or whatever else is handy, be careful with the hinges because you have to have a tough material.
2. Hinges, As we did in width 2cm * 2cm thick, I found them in my nearest hardware store.
3. Table 14 cm long * 7.5 cm W * 1 cm thick, The available in a wood shop, free, generally, find the table in the waste, and has sometimes no cost, you can increase the size of the table, it depends on weight and size of the camera. My table exceeds the size of the camera.
Tools
1. Drill or screwdriver
2. Sierra flat, to avoid this you can ask q cut.
3. sandpaper to improve inaccuracies.
4. metro,
5. colbon, not just to grab the timber, you can place a drop of good colbon on the hinges to improve grip, if you work with wood of course.
Spanish - Español
1. Madera De 2 cm * 2cm * 96 cm
Como hacerlo; busque y encontre en los desperdicios de madera 3 lamina de triplex (madera) de 9mm casi con 2 metros, como era muy delgada entonces la corta en dos y pegue las seis partes, esto me dio 3 partes de 2 cm * 2cm * 96 cm, que serian los tres pies. También puedes hacerlo de otro material tubos de PVC o cualquier cosa que tengas a la mano, ten cuidado con las bisagras pues tienes que tener un material resistente.
2. Bisagras, Como lo hicimos de 2cm ancho * 2cm grueso, yo las encontre en mi ferreteria mas cercana.
3. Tabla 14 cm largo* 7.5 cm ancho* 1 cm grueso, La consiguen en una tienda de madera, gratis, generalmente, la tabla la encuentras en lo desperdicios, y no tiene a veces ningún costo, puedes aumentar el tamaño de la tabla, eso depende del peso y tamaño de la cámara. Mi tabla supera el tamaño de la camara.
Herramientas
1. Taladro o atornillador
2. Sierra plana, para evitar esto puedes pedir q te lo corten.
3. lija, para mejorar incorrecciones.
4. metro,
5. colbon, no solo para agarrar la madera, puedes colocar una gota de un buen colbon en las bisagras para mejorar el agarre, si trabajas con madera por supuesto.
6 comments
Jun 22, 2010. 7:34 PMmee-mee says:
i think's the first spanish-english instructable ever! me encantaaaa ademas me encanta tu trípode es tan ...moderno i love your tripod is so...modern? (haha i don't konw how to say that in english) si hiciera uno lo pintaría de negro, no se una sijerencia...
Nov 26, 2009. 7:02 AMwackman says:
Muy buen instructable. Gracias por el detalle de escribir también en español. Ojalá cunda el ejemplo.
Very good instructable. Thanks.
Nov 22, 2009. 2:19 PMlemonie says:
I see it. Is there no screw-mount for the camera?
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Franzjr(Franz Joseph Rogelez)
