Remove these ads by
Signing UpStep 1Parts and tools
This camera is a typical Quickcam. It has a little attachment on the bottom that snaps into a base - it does not clip onto anything, and the base is about 3 cm high. It isn't shown here because I have no idea where it is.
I got a coupling nut that is threaded for 1/4 inch-20, which is the standard size for a tripod attachment, and is an inch long. I also got a 1/4 inch-20 screw that will fit into it, and it is 3/4 inches in length. The screw is a countersunk machine screw, and I got a countersunk one because I figured that space is a premium inside the webcam and I could use this type of screw without the head protruding into the body of the 'cam.
To open up my webcam, I needed a Phillips-head jeweller's screwdriver, and I needed a drill with a 1/4 inch bit and a larger bit (or a countersink bit) to drill the hole for the screw. I also needed a vise. I used Loctite on the screw threads. A large screwdriver and wrench were needed.
www.instructables.com/id/Webcam-mount-for-any-laptop-or-screen-cheap-and-/
maybe this will help you, and if you want you can modify it so that it has a tripod screw for a lightweight camera.
www.instructables.com/id/Tennis-Ball-Tripod/
and cut the ball so that it has 4 legs to the tripod instead of three, and cut it in such a way that the legs of the "tripod" are exactly the same as the thickness of the monitor, so that it will slip over the monitor instead of resting on top.
Thanks a lot!
