Tripwire Alarm
Published
Introduction: Tripwire Alarm
About: I have always loved woodworking and inventing. I will try to post an instructable about everything that I think is good. Visit my website to see instruction videos about home improvements with general contra...
In this instructable I will show you how to make a simple tripwire alarm. If you have any questions please comment.
Here is a video of the first test:
Step 1: Supplies
You will need:
-an alarm/buzzer
-wire
-tinners tape
-batteries and holder
-clothes pin
-duct tape
-thread
-cardboard or a thin sturdy material
-switch
-screwdriver
Step 2: Step 1
Cut small pieces of the tinners tape and cover the end of both sides of the clothes pin. Then put the two wires on the outside of the clothes pin on the tinners tape and tape them in place.
Step 3: Step 2
Attatch the negative wire to the alarm. Then attatch the positive wire to the switch.
Step 4: Step 3
Attatch one of the wires from the clothes pin to the switch and the other to the alarm.
Step 5: Step 4
Mount the clothes pin just under knee high on the door frame. You can leave the alarm, switch, and batteries on the floor.
Step 6: Step 5
Cut out a small piece of cardboard with a small hole near one end. Tie thread to the cardboard, DO NOT CUT THE THREAD
Step 7: Step 6
Open the clothes pin and clip the cardboard into the clothespin to separate the two sides and break the circuit. Measure how long the thread has to be to reach the other side of the door. Cut the thread and tie it to something on the other side of the door, I tied it to the door stopper.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    6 Comments
    I glued a staple to it (ill pit pics later)
    Tinners tape is used on heating ducts. You could use aluminum foil too, it just will come off easier because it isn't sticky.
    ok thanks. tried your nerf to airsoft thing. Works great.
    It is very nice and you can use it for other purposes also like have one end of the thread in a band and wear it in your hand and the other end with the clip inside your wallet or purse so when someone snatches it the alarm will go off
