3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Trolling motor made from wood
video Trolling motor made from wood
The basic idea of this trolling motor is the multi functionality of the cordless drill.
Is the power of a battery drill enough to drive a trolling boat on still waters?
The answer is yes. I made the trolling motor from wood and some other parts in a
Clear design with Clean materials and Cheap. So, the 3 C's.
The outboard is partly inflatable for easy transport. Two nails are locking the hinge
and the steering handle. All the functional parts are there, motor, propellor,
hinge with lift and the steering handle with trottle. Building time is about 3 hours.
A test with a canoe was convincing although a drill with a higher speed is advisable.
I also used a battery adaptor for connecting an external 12V gel battery of 12AH.
Enough to navigate for a while.   Website: http://www.safarana.org
11 comments
Oct 22, 2011. 2:17 PMmajshanman says:
Bertoa, I am in Iraq and your video is blocked by our firewall (or whatever it's called). Would you mind posting or sending photos of the project? Thank you!
Aug 12, 2011. 10:15 AMPhil B says:
I had to view the video without audio, but all was still clear to me. Not only is this a clever idea, but it is very nicely executed. I wondered about the wing nut on the tiller handle assembly and thought a self-locking nut might keep it from coming loose. Also, is there any danger of water working into the gears on the angle head driver? Perhaps all of that was covered in the audio portion that I missed. Thank you for an interesting and useful Instructable.
Aug 12, 2011. 9:38 PMPhil B says:
The computer I was using has no speakers connected to it. I sure I could have heard the audio if I had speakers available for that computer. It sounds like you have all contingencies covered.
I never expected to have 186 Instructables, but kept thinking of solutions to problems and wanted to share them. Some of the Instructables are better than others. Thank you.
Aug 11, 2011. 2:43 PMRedneckEngineer says:
Good idea, great application!
Anyone ever tell you, you look like Red Green without the duck tape? :)
Aug 11, 2011. 3:46 PMrimar2000 says:
Great job!
This remember me that some 30 years ago I made a centrifugal water pump in phenolic plywood, successfully. I used it for filtering the water of the canvas pool.
The metalic parts were only the axis, the hub and the rotor (2 brass blades) The motor was the drill.
Aug 11, 2011. 3:46 PMdasimpson1981 says:
you need a prop more suited to the lower rpm
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Bertoa(SAFARANA foundation)
Born Handyman. Member Repair Cafe Maastricht.
