Once you feel comfortable doing this, you can try endless variations, with seaweed, scallions, peppers, garlic, fish sauce or broth... in many ways, depending on how you dress it up, this can be very similar to Korean Kimchi.
There is no vinegar added.. like all naturally fermented pickles, the varying sourness is from natural vinegar that gets made as part of the fermentation process, so while you can simply put salt and vinegar on cabbage, not only would that be "cheating" but it would cheat you of the full flavor and priobiotic benefits to the gut and immune system, that naturally fermented original versions offer.
Once you see how simple this is, you can have it all the time, and it is good with rice, alone as a snack, added to soup after the soup is done, on sandwiches like sauerkraut, or however you like it.
This is quick to make and must also be used more quickly, than slower fermented things like kimchi. But it's easy enough that there is no need to make more than you can use in a short time.
Remove these ads by
Signing UpStep 1Tools and Materials
Oh, and a makeshift "tsukemonoki" if, like most of us, you don't have access to a traditional Japanese pickling crock. Use any container that is big enough, and lets you weight the top down. I used a 2-quart square food-safe plastic freezer storage container, with a 1-quart one full of water as the weight. You could use a large nonreactive bowl with a plate on top weighted by a brick. Or if you have a tsukemonoki, tell me where I can get one too.
As for rinsing when it tastes too salty? You can, but be aware that that may cause it to take longer to ferment properly since you will be washing out much of the active organisms... it might set it back a bit, and if you remove that plus a little too much of the salt, it could just plain spoil. It is something to experiment with.
If it is not too salty to ferment, you could also try rinsing each portion briefly before using, or else adding a small amount of water to your container, to let the salt level soak out a bit, while the juices continue to sour, so you won't lost the flavor. then you can use the extra juice in soups or whatnot.
The best part of home crafted fermentation is that you can play with it, see what happens, and seek your own taste of perfection.
If you find that it is, just rinse out the portion you plan to eat.
When I rinse mine, I leave it in a strainer to stand for about a half hour to let it drain and dry out a bit before serving.
Typically, I use about 1/4 cup of regular pickling salt to 2 quarts of dry chopped veggies.
