3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tub o' Water Solar Heat Exchanger
video Tub o' Water Solar Heat Exchanger
Hey Everyone.
Here's a simple experiment. I hooked a 4'x10' solar hot water panel up to just a small (3 watt) pump and a 60 foot coil of 3/8th" copper pipe set down in a tub of water.
I wanted to see how effective the solar panel would be at transferring heat through that copper coil into the water in the tub.
Since it was below freezing the night before, the tub of water started off with a half inch of ice on it. Three hours later, the water temperature was up to 140 degrees!
This tub holds between 10 and 15 gallons. When I finish experimenting. I plan on using an insulated 50 gallon tank in my house with TWO coils of copper pipe in it - one for anti-freeze circulating through the solar panel, and another one for fresh water from the well to warm up before going to the traditional water heater.
I think I will also use 3/4 inch diameter copper pipe for the domestic water loop, as it will hold more volume, the main water line is 3/4 inch, and it will give less resistance than smaller diameter pipe.
8 comments
Mar 23, 2010. 8:50 AMrimar2000 says:
Maybe you don't need the water pump. Convection does the work free...
Jan 23, 2012. 1:20 AMrgrimm1 says:
Please be aware, distance and a small diameter pipe will prove to be a problem. Between heat losses along the way (even with insulated pipe) and internal friction in the pipes, flow will be decreased. Indeed, I have been told by plumbers that every 90 degree bend in a pipe was the equivalent of 10 more feet of pipe, friction-wise.
Incidentally, this was found out when they were building the Manhatten Project for the Bomb. Turns out the efforts there to improve efficiency by making pipe runs as straight as possible also reduced amount of pipe significantly.
(Actually, they did it originally to prevent radioactive solids from collecting in corners of pipes, but the efficiency was a bonus.)
I've see three solar heat setups that used a solar powered pump. On cloudy days, the pump does not work as fast (less juice) which is OK as the solar collector does not pick up as much heat as on a sunny day.
Somewhat self-regulating.
AND check valves were added, just to keep the unit from flowing backwards during night and other cooling-off periods.
I take it you do not have space or location to do batch solar water heating?
Oct 29, 2010. 1:44 PMMr_Sea-Breeze says:
You could always use a small PV panel to drive the pump...
The stronger the sun; the faster the antifreeze is pumped around and conversely (and more importantly) the weaker the sun the slower the pump leaving the antifreeze in the panel longer to absorb more of the suns heat.
just a thought...
Jan 22, 2012. 2:08 PMwikkit says:
The heat transfer is related to the velocity of the fluid in the pipe. So while a large diameter pipe will lose less pressure, it will also not get as much heat transferred to it.
In a fuel-cooled rocket engine, for example, the fuel flows through the cooling channels at somewhere around 10 meters per second.
Apr 18, 2011. 2:47 AMuberdum05 says:
You said in your video that the water that was in the tub with the pump was colder than the other tub. I have a theory for this - it is because the hot water from the solar panel flows into the copper coil thus transferring most of the heat into the bucket of water rather into the other bucket with the pump :)
Jan 16, 2011. 2:13 PMsparks says:
Thanks for sharing that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
283
Author:bennelson(300MPG.org)
Ordinary guy with no special skills, just trying to change the world one backyard invention at a time. See more at: http://300mpg.org/ On Twitter - @300MPGBen and at Ecoprojecteer.net
