Step 4DISCHARGE THOSE CAPS!!!!!
The 'filter' caps can store fatal amounts of electrical current. The caps are connected near the rectifier and are part of the power supply, and aid in converting AC to DC. In fact, they are a standard component in any power supply.
If you're completely lost, and don't understand this, DON'T MODIFY YOUR AMP. You haven't enough knowledge to work on high voltage/current circuits safely...
Several ways to discharge caps:
FIRST, UNPLUG THE AMP! (But that doesn't make it safe....)
THEN,
--Take a screwdriver or a jumper and short the capacitors leads.
--OR jumper the power amp tube plate pin to GND for a minute or so (Class A, single power tube only.)
--OR jumper the positive (+) lead of each large cap to GND for several seconds. A jumper with a built-in resistor (10K or so) will help prevent sparks here...
Some, or all of these methods may result in a spark... Obviously, your flesh can act as a jumper also.
It's NEVER a good idea to touch amp circuitry when it's switched on. If you're stupid enough to do it, NEVER USE BOTH HANDS--that way, there's at least a slim chance the current won't flow through your heart.
And don't work on amps in bare feet, on a damp basement floor. :-(
Don't even play your amp in this fashion...
If you're not willing to learn (or unwilling to take the risk), seek out an experienced amplifier technician.
I've been dumb enough to play my old Ampeg in the basement with barefeet....wasn't a painful shock, I could just feel the current flowing from my left hand to the floor. One lesson learned.
Because AC line plugs were all two prong, the amp has a two-position standby switch. This switch not only works as a standby, but it also connects the AC line to the chassis through a single capacitor.
Since the plugs weren't polarized, you could use this to connect the chassis ground indirectly to the line 'neutral' wire, and your amp would run quieter. But if the cap degrades and fails, and your guitar strings are grounded (as most are)--it's like poking your finger in the wall socket...
On cheaper amps without a standby switch, the cap was still there, but you'd change the plug direction to ditch the hum...
(picture: red square shows the switch and the 'death cap.')
Leave it jumpered for a minute or two...it's probably draining through the output transformer.
If you have any questions, send me or post a schematic for your amp, and we'll figure it out.
Also, I don't know which version of the VJ you have, but the newer ones have a bleed resistor in the power supply to drain the caps. Since they need to be high resistance (so they don't mess with normal operation) they will take 30 minutes (or maybe more) to work.
You can always check the caps with VOM to be sure they are drained, too.
Here's a pretty good discussion of VJ mods, don't know if you've seen it.
