The first thing you got to do is remove the chasis before you can proceed with the case. These radios are great for that reason. They are fully serviceable. Just four screws under the case and it slides right out. Something you can't do easily with more new radios. While I had the chassis out, I went ahead and redid the capacitors(although it didn't hum) and cleaned out the tuneing components. All this was a job unto itself. Other than that It needed a new tube installed and a dial light bulb. The rest of it worked as it should. I didn't do anything to the dial face because I wanted it to have some originallity left in it for that nostalgic feel. As you can see from the pictures how they built these radios in the day was great, nothing in it was cheaply made, all the components were metal and made to be replaced if broken. The hardest part is locating them if they are broken in todays world. But the engineering was just well done and in the USA.
And unless you are a purist you could use replacement transistors in stead of those hard to find tubes.
Otherwise, great work. Glad to see someone fixed up a wonderful old device without making it "better" by gutting it and putting in some $5 powered speakers and an iPod connection, and painting it some ridiculous Andy Warhol scheme. Classy baby blue is definitely a '40s look. Well done.
As concerns the lack of a transformer, these radios economized to make a less costly design. There are usually five tubes. The heating element in each is designed to consume 25 volts. The tube heating elements are in series, so in a 125 volt household circuit, 125 volts is consumed and no transformer is needed for a power supply.
It has been about twenty years since I had to buy an electron tube. They were becoming less available then. I am surprised you were able to get the tube you needed, but, maybe I should not be.
When I listened to "popular" music during my teen years, it was most often by means of a tube radio. A few years ago someone gave me a couple of old tube radios. From the two I was able to make one work pretty well, at least for a while. I listened to an oldies station with it and was surprised to rediscover favorite music as I originally heard it with all of the pops, wows, and hisses that are part of AM tube radios. The super-clean sounding FM oldies stations are nice, but, the extra noises made the experience a real authentic trip down memory lane.
