Tube Worklight LED Conversion
1,983
10
6
Posted
Introduction: Tube Worklight LED Conversion
This is an old faulty fluorescent tube worklight which I converted to use LED technology.
The old tube light had blown capacitors and inductors and had been repaired before finally giving up the ghost. The light output was poor and also flickery.
I was going to buy a new led worklight, but then I had a brainwave to upcycle the old one to LED at a fraction of the cost.
Step 1: Parts List
Parts (available from banggood):
* old fluorescent worklight (for case)
* 5watt 50cm LED light strip with aluminium heatsink backing and lens cover. I prefer cool white rather than warm white for working.
* 10watt 12v led power supply (mini board to fit within tube handle.
* 4 terminal block connector
Tools & Skills:
* soldering iron
* hacksaw
Step 2: Upcycle It
unplug worklight
This tube light was held together by plastic studs. 1 above, 1 below the clear tube. Remove studs using narrow jewellers screwdriver.
Pull top and bottom away from clear tube.
Slide out fluorescent lamp, wiring and circuit board.
Disconnect mains supply cable to board.
Connect mains supply wire to new 12v board using 2 terminal blocks.
similatly run 2 short pairs of wires from 12v output via terminal blick to led strips.
My tube light could comfortably take 2 led strips of 25cm each. So I cut the 50cm led light strip in 2 halves. Solder the 12v wires to the strips noting correct polarity.
I managed to wedge two strips of heatsink & lens with two led strips into the clear tube (rattle free and acts as a heatsink to keep leds cool)
reassemble light and pop back in the plastic studs.
Step 3: Test It!
Simple, plug it in and check the light output.
I was so impressed I did a 2nd tube light in warm white.
Congratulations, you now have an LED workight which is:
✔much brighter than a tube
✔more reliable than an electronic ballast
✔instant full brightness on power up
✔ half the power consumption
✔ a fraction of the price of a new one
✔ cheap and simple to maintain
✔ done your bit for the environment.
Now go treat yourself to a beer ☺
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    6 Comments
    Finally I find a kindred spirit in the Warm white vs. Cool white argument.
    zapp
    The smd 5630 leds do not require an al heat sink......why unneccesarily ise one?
    it came with the led strip and i needed something to fill the void in the tube. so why not use it if it fits ☺
    Oh didn't know you got it along with the strip........ Just saying because it unnecessarily increases your project cost...........
    total cost $7 or about £5.
