Tubular Art
747
18
5
Posted in CraftArt
Introduction: Tubular Art
Need some art to adorn your walls? How about a modern art assemblage. This is an easily reproduced work surprisingly simple to accomplish. The ingredients are humble paper towel and wrapping paper cores along with some corrugated cardboard, assembled on a box, glued and painted. Four easy steps. Let's get started.
Step 1: Gather Cardboard, Supplies and Tools
1. I don't use a lot of paper towels. So I asked friends to save their paper towel cores for me. I ended up with a core from gift wrap after Christmas and I got 3 commercial paper towel cores from work. I counted 13 cardboard cores in this project.
2. I tore a flap off a large corrugated cardboard box
3. Large bottle of white all purpose glue
4. Wet hand towels to wipe fingertips and spot clean drips and drops
5. A box to mount your tube assemblage. I used a box from a large game set I purchased at the thrift store it happened to be the right size for my project. Any sturdy cardboard box or lightweight wood box will do as long as you like the size with your piece.
6. Acrylic craft paints. I used matt and metallic colors. Limit your palate to 5 or 6 colors.
7. An acrylic artists paint brush. I used a half inch wide square tip brush.
8. Newspaper or cut down grocery bag to protect your work surface and make clean up much easier.
9. A plate for paints.
Step 2: Designing and Gluing
1. Lay the box on your work surface so the solid side is facing up.
2. Lay out your cardboard tubes on top of the box.
3. Move the tubes up or down to create your design. Use an imaginary irregular diamond pattern for placement of the ends of the tubes. This will help your design be more pleasing to the eye. Try not to line the tubes up like soldiers. Some tubes should stick out beyond the box on both ends.
4. Tear off the surface of the corrugated cardboard so the corrugation is exposed. Make several sizes to use with the exposed corrugation running horizontal and vertical for the design.
(refer to the photos for examples for design and layout)
5. Open your white glue. I took the cap off. I slung glue back and forth right to left making thin and thick lines allowing the glue to puddle and drip. The more passes with the glue the more puddles and lines across the tubes. Don't be afraid to scoop up big puddles of glue with your corrugated cardboard using the excess glue to stick down the pieces of corrugated card board. The glue will dry lumpy and make ridges adding to the surface texture.
6. Let it dry. I positioned a utility heater with a fan a safe distance from the piece to dry the glue. Check the pieces to make sure they are attaching to each other and the mounting box. Make sure you get good glue adhesion between the pieces.
Step 3: Painting
1. Assemble the selection of acrylic craft paints, brush and plate.
2. Start by squirting out a good amount of one or two colors. Don't be tempted to try to dump all the colors out at one time acrylic paint will dry up too fast.
(see photo)
3. Start with matt colors first. Cover the tubes, the areas between the tubes that can be seen, the inside ends of the tubes and the corrugated cardboard with a good coat. Use a dry brush technique to highlight the texture ridges left by the dried and puddled glue.
4. Finish with the metallic colors to highlight and emphasize the shapes and surfaces of this modern work of art.
5. Take a break, go get a drink of water, come back, and check your work over again before you put up your paints.
6. Acrylic paint clean up is easily accomplished with a warm soap and water wash then rinse until the water runs clear.
7. Let the paint dry completely.
Step 4: Hang It
Use your favorite picture mounting hardware to hang your artwork on the wall, step back and enjoy.
    • Trash to Treasure
      Trash to Treasure
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    5 Comments
    Dear,
    My name is Fabiana and I work
    for Editora Moderna in Brazil. Moderna is part of the Spanish group
    Santillana.
    We publish textbook and books
    for all grades and our material are very recognize throughout Brazil, even in
    public and private schools.
    Right now our team is working in an book
    named Peace vol 3 by Eduardo Amós, and to enrich even
    more our material, we'd like to use the following text from the webiste:
    Tubular art - https://www.instructables.com/id/Tubular-Art/?ALLSTEPS
    We’d like to use this text in the printed
    and digital book. And the printrun will be 5.000
    copies.
    Attached is the text we’d like
    to use.
    So, we’d like to know how
    should we procedure to get the authorization to use it.
    Please, if you have any
    question, do not hesitate in contact me.
    Best wishes,
    Fabiana
    Dear,
    My name is Fabiana and I work for Editora Moderna in Brazil. Moderna is part of the Spanish group Santillana.
    We publish textbook and books for all grades and our material are very recognize throughout Brazil, even in public and private schools.
    Right now our team is working in an book named Peace vol 3 by Eduardo Amós, and to enrich even more our material, we'd like to use the following text from the webiste:
    We’d like to use this text in the printed and digital book. And the printrun will be 5.000 copies.
    Attached is the text we’d like to use.
    So, we’d like to know how should we procedure to get the authorization to use it.
    Please, if you have any question, do not hesitate in contact me.
    Best wishes,
    Fabiana
    Dear artist, the editors from a brazilian didactic book called "Peace", that teaches english language for brazilian children, would like to use this 4 images of your work. Would you authorize the use, please? My email is giu@yancom.com.br , could you please send me an email and teel me yes or no. Thank you!!!
    Ooo so pretty, never would guesses it was made from cardboard tubes! Hope we see more from you in the future!
    Thank you. It was fun up-cycling these disposables into something like this. When I do this again I will be bolder with the glue texturing on the tubes, I think that was my favorite part because painting it was like opening unexpected gifts. I didn't know what I would get until the paint revealed the surprises.
