Tulip Tower Loom Bracelet
Introduction: Tulip Tower Loom Bracelet
This is an easy and fun bracelet for you and it is really beautiful good luck
Step 1: Things Needed
Things you need for tulip tower bracelet
A loom
A hook
Some rubber bands
A C or S clip
Step 2: Placing Bands
Now you have to place bands
Place a band facing with the arrow facing forward as you can see in the picture above
Step 3: Placing Bands
Then place a band to the left and then to the right easy
Step 4: Adding Bands
Then add bands from the right to the bottom peg and from the left to the bottom peg
Step 5: Placing Bands
Add another green coloured band and then a white or yellow coloured band and do the same as i am using pink and yellow for flowers well it is your choice you can use any colour you want
Step 6: Cap Band
Place a cap band on the last peg on top of the band i hope you know how to add a cap band it is easy on your finfers turn the band into an 8 shape the carefully place it on the peg there would be 2 layers of the cap band dont forget to notice that
Step 7: Lets Get Hooking
Now start hooking go inside the cap band take the first band you see and place it on the peg which you get
Then same with the left peg
After that to the front peg
Step 8: Hooking
Then from the left peg to the front peg and from the right peg to the front peg
Step 9: Hooking
Do the same till the end i hope it is easy
Step 10: Almost There
For taking off the bands, take your hook inside the last peg of your loom and from the inside to the outside tyen add a band to it and reverse back from the inside to the outside but be careful do not let the band in the hook let out
And now take it off the loom
Step 11: Extension
Now for the extension , place your incomplete bracelet only the last band like a cap band on a peg of the loom
Then add bands for a single chain extension like this above
As you now you have to add a cap band instead of the cap band add the bracelet's last band and it should be place like a cap band
Then start hooking from the cap band and you will have your single chain extension ready
Step 12: Taking It Off
Take the single chain off like this
Hee you have your extension but you see it is too small for you do the same for the other side of the tulip tower bracelet
Look here you have it
Step 13: Finishing Touches
For the finishing touch yu have to add a s clip
Add a s clip on each of the end of the bracelet
Step 14: Congrats
Congratulation you have completed your bracelet
Now dont forget to comment share and make it one of your fave pleaseeeeee
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
