loading
Step 4: Prep ingredients and stuff bird
Cut the carrots, onions and celery into large chunks. Chop 1/2 of the sage, 1/2 of the parsley and 1/2 of the thyme, leaving the rest of the bunches intact.
Preheat the oven to 375 degrees F. As you can see from my picture, setting my oven temperature is a bit of a guessing game at my house. I use a thermometer that lives inside the oven to know how hot is in there for sure. This is a good idea for anyone, since many ovens don't have the best thermostats.
With the oven pre-heating and ingredients chopped, it's time to stuff the turkey.
Start by taking one quarter of an onion, a piece of celery and a chunk of carrot and stuff them inside the body cavity. Continue stuffing some of each items inside the turkey until the turkey is full. Don't jam too much in there. A stuffed turkey will quickly give you diminishing returns since the more you put inside, the longer the turkey will need to cook for, and the dryer it will be.
Tie the remaining bunches of parsley, sage and thyme together using a piece of butchers string and place them inside the turkey with the rest of the stuffing.
I've moved away from stuffing turkeys with an actual bread based stuffing. The increase in mass slows the cooking process down, forcing the turkey to cook for too long, and thus dry it out. The onions, carrots and celery are just really there to impart flavor to the meat and drippings, not to be eaten as your typical Thanksgiving stuffing. To learn how to make a great stuffing that's prepared entirely outside of the turkey, check out scoochmaroo's Stuffing.
I have friends who swear that it's all about brining the turkey first. Here's their recipe:<br/><br/><strong>Brine Recipe for Turkeys</strong><br/>For each 2 gallons water<br/><br/><ul class="curly"><li>2 cup Kosher salt (less salty than table or sea salt) or 1 &frac12; sea salt</li><li>2 cup sugar</li><li>sage (Fresh herbs where possible)</li><li>rosemary</li><li>thyme</li><li>8 bay leaves</li><li>cinnamon sticks</li><li>cardamon seeds</li><li>large chunk of ginger cut up</li><li>peppercorns</li><li>juniper berries</li><li>garlic cloves</li><li>2 oranges</li><li>2 lemons</li><br/></ul>Bring to a boil for 5 minutes. Let cool, add 1 gallon apple cider. Brine bird for 24 to 48 hours. Rinse off well and cook.<br/>
Been looking for a brine recipe...so, does it take 2 gal. of water to do just one bird? How big must the container be to soak that sucker in the frig? Or can you put it in some sort of bag and do it in an iced-down beer cooler? Thanks, JJ
To hold turkey+brine, we used a plastic file container we bought at Big Lots for $2. Worked perfectly!
<p>best ever</p>
<p>great </p>
<p>Awesome instructable thanks for sharing ! I'm going to taste this. 1 of my favorites is <a href="http://healthy-dietrecipes.blogspot.com/2012/06/chicken-cacciatore.html" rel="nofollow"> Chicken Cacciatore</a> Easy to make but so delicious.</p><p></p>
Awesome instructable thank you soooo much I placed the toothpicks like you do in the photo but what exactly is the purpose?? great finished product thanks again!!
This is disgusting! Celebrating what you have, Thanksgiving, killing an animal just for pleasure? Would you like someone else did that to you with the excuse of &quot;Christmas&quot;?
sounds tasty <br>
My school of thought here is that since the veggies are crammed inside, they lack the proper temperature to cook fully. You could achieve the same goal by placing them around the bird, allowing them to swim in the broth you have created by adding all the herbs to the cavity and flushing it with baster every hour. <br>A cold turkey inside means a raised risk of salmonella and we can't run that risk. <br>Simply stuff two sliced lemons inside and squeeze them and they will help keep the bird moistened while it cooks they absorb the broth and give off steam.
The process of rubbing down a turkey with salt and then rinsing it off again is obligatory, it serves no real purpose since the salt being rubbed on, and then rinsed off actually gives no flavor to the finished product. <br>My suggestion: <br>When the turkey is ready for the oven, spread a layer of good olive oil on the bird, rub it down, then a handful of Kosher Salt, pepper, and various seasonings, (thyme, sage, rosemary, parsley) whatever you choose. <br>This way at least when you baste the turkey with the chicken broth, you retain flavor and spread all these herbs throughout the turkey cavity and on the skin as well.
delicious looking turkey.
I've roasted my first turkey in my life. My Dad was speechless when he tasted it. Thank you very much for this recipe! :) It was a complete success, my family loved it!
Wow. It looks very delicious.
So nice, so interesting. I will make this on my birthday
Just wanted to say thanks. At age 46, I finally cooked my first turkey, using this recipe, and it came out fantastic! Really easy, actually. Used an 11-lb bird, and amazingly, it was cooked perfectly in 2:15' (so plan accordingly for smaller turkeys!) <br><br>The only difference was that we used a roasting pan with lid, so no tinfoil involved. <br><br>Also made my first gravy and first stock - all came out great.
this is my way for years.good anyway you do it yuuuum.happy turkey day to all.
I recommend leaving the pop-up thermometer in place until the bird is completely cooked and rested. If you remove it before the juices have redistributed, juices will escape from the hole. Doesn't really matter if it's popped or not. Remove it just before you serve it. <br> <br>Also, if you brine, I found adding apple juice or cider to the brine makes the bird a deeper reddish-brown...very GBAD.
This looks like a really good recipe. I'm going up north for Thanksgiving, so we're doing turkey Mom's way this year... will try this next time. :) We usually do it the way Grandma did:<br><br>Melt 1/2 to 3/4 cup of butter in a pan, add 2-3 cups of flour and mix in. Cool it a bit. Use your hands to cover the top and sides of the turkey, including the legs and wings. Bake it. Right before its done, make a pot of water with onion soup mix. When the bird is done, scrape the flour/butter mixture into the pan. Add the pot of onion soup and cook on a low heat while you loosen all the pan drippings and mix the flour in. You now have a very nicely crisp and browned turkey, with tons of sumptuously rich gravy. :)<br><br>
Thanks for sharing Grandma's method of making the turkey, most importantly, GRAVY !<br>Just to clarify, melt the butter into 2 to 3 cups of flour? Seems like it would be very stiff.<br>Please reply if you see this sandyrubicz@gmail.com<br>Thanks<br>Gobble-Gobble !<br>
Melt the butter in a pan, then add the flour. This makes a roux paste which will stick very nicely to the outside of the turkey. You can also add some seasonings to this if you want, like salt and pepper or poultry seasoning. The butter and flour roux will take on a nice golden brown color and flavor, adding flavor to the gravy. Add extra water if needed. From a large bird, you can easily get 10 cups of gravy. It takes some time to dissolve all that flour, so someone needs to be working on gravy, while someone else does the turkey slicing and getting all the food into bowls, but its well worth it. We usually end up with enough gravy to last as long as the leftovers.
I love this instructable. I do a very similar Turkey and do only one thing different. <br><br>I rub the herb butter between the skin and meat. You just use a spatula to gently peel the skin away from the meat, load it up with herb butter, and rub it around inside. It really adds flavor to the meat. Try it sometime. The skin is much stronger than it seems so don't worry too much about it breaking.
My 7 year old was dissapointed that she has never seen a turkey, either on Thanksgiving or the 2 or 3 times each year I cook one, all laid out on a platter with the veggies around it. She really wants me to do it that way next time. I chuckled and told her that you only see that on TV - it gets too cold to let it sit there on a plate to carve, etc. <br> <br>....But I'll have to do it this way because (1) it looks yummy and (2) I'm kinda a sucker for indulging my daughter on these little things :) <br> <br>Thanks!
Sounds good to me!Thanks
How would you adjust these instructions if cooking the stuffing separately? I assume the bird would cook from inside more quickly? (and if so, how much more quickly?)<br><br>Also: What would you estimate would be the total cooking time for a 11-lb turkey?
I used a Jennie-O (already injected) 18 lb. turkey....added green onions with bulbs to the cavity.....didn't peek for 3 hours.....basted uncovered for 2 more hours....the digital thermometer read 175 degrees......made a gravy with corn starch.....best turkey I have ever roasted in my life!!!!&nbsp;&nbsp; Next time I'll quarter my carrots and cut the celery stalks smaller too....the veggies will be an addition to the other food....best recipe ever in my book....I didn't apply the Kosher salt but once....no need to rinse....added garlic powder to the seasonings......perfect!
Since my 18 lb. Jennie-O came already injected I decided to go directly with the Kosher salt and ground black pepper.&nbsp; I added garlic powder to the bird as well.&nbsp; I foiled the pan and did not peek until the 3 hour mark and basted away for the next 2 hours.&nbsp; The digital thermometer showed 175 degrees and it was cooked.&nbsp; This is the best turkey that I have ever cooked.&nbsp; The fresh herbs and veggies really made the difference!&nbsp; Thanks for sharing with us!!<br /> HappyGuy54
Be careful when brining a turkey. It must be a fresh, unprocessed bird. Most of the commercial brands have been injected with a salt/water solution to allegedly make them juicer. If you brine this type of bird you will be sorry. Remember fresh is best.
Why will I be sorry? What happens when you Re-Brine a Turkey?&nbsp;
The amount of salt will be too high. A fresh, unprocessed bird&nbsp;soaked in&nbsp;a brine you make will give you much better results.
okay seriously, best turkey recipe ever.&nbsp; I don't know if we tented it really really well or something but our 21.4 lb turkey cooked in 2 hours to 170 degrees, it was juicy and delicious but we had to crisp the skin so we just took the foil off.&nbsp; We didn't add stock because we forgot but the veggies and butter with herbs provided so much we had a ton of gravy.&nbsp; Thank you so much!&nbsp; Know any more? <div id="refHTML">&nbsp;</div>
it's very nice<br /> tanx
WHEN THE THEMOMETER THAT LIVES IN YOUR OVEN SAYS 375 YOU COULD TAKE A PENCIL AND MAKE A MARK AND&nbsp;375 BY THE OVEN DIAL SO YOU'D REALLY BE IN THE BALLPARK, FOR EASY REFERENCE AND ONE LESS THING TO MESS WITH...
Wow! First, I've never seen such nicely written description of a recipe in any other site. My favorite have been the <a rel="nofollow" href="http://123recipes.com/Recipe/Holiday-Turkey-Recipe/Detail">turkey recipe</a> at 123Recipes.com. But I am gonna try this one next... The pic looks so inviting.<br/>
1) 155 F in the breast and rest to get 160. Use a wire rack and the thigh will be just fine. 2) Good idea with the flavored butter but get nearly all of it under the skin even if you brine. If you brine use unsalted butter. 3) Try to brine with an un-injected turkey. You'll know by the label. 4) Reduce a large amount of your favorite beverage that goes with turkey to nearly a syrup and combine with the compound butter; in the past I have used sherry, chardonnay, gewurtzraminer, liebfraumilch, and American Pale Ales with great success. 5) I get that you feel under scrutiny at these holidays but cut yourself some slack...........roast, fry, smoke, grill........whatever you want as long as you and the family have fun. Otherwise, go out to eat and give someone else the money and satisfaction of a job well done.
where is this stock listing needed in step 7 in the 'gather materials' step????? attention to detail... might cost me my turkey dinner...
I just added it in. A thousand pardons, I really hope I didn't cost you your turkey dinner.
great instructable!
That is without a doubt the most beautifulest looking turkey Ive ever seen in my life. Looks like the meat just falls off the bone. Hmm hmm, im coming to YOUR house this year! LOL
NOM NOM NOMilicious!!!!!! (8O)>
Step 3 seems like a waste of salt to me. But otherwise, awesome Instructable!
The USDA recommends that all fowl be cooked to a minimum of 165F in the center of the thickest parts of the meat to eliminate, or at least make improbable, the likelihood of food born illness. The temperature should be checked in the thickest part of the breast and the thigh. This should be done even if there is a &quot;pop-up&quot; thermometer installed in the bird. When a bird is stuffed you must also insure that the center of the stuffing reaches a minimum of 165F. In my 4+ decades of turkey roasting experience (we serve turkey 6-8 times per year in our home), the center of the stuffing will not reach 165F until long after the breast and thigh have reached 165F. This results in an over cooked bird. Heating the stuffing before it goes into the bird helps. I also insert a 5/16 in. dia. x 16 in. stainless steel rod into the stuffing to help transfer heat into the stuffing. Stuffing the bird also increases roasting time so I seldom stuff one anymore. In fact, now that I have a turkey frier, I seldom oven roast a turkey. Here is the USDA site for roasting turkey safely:<br/><a rel="nofollow" href="http://www.fsis.usda.gov/Factsheets/Lets_Talk_Turkey/index.asp">http://www.fsis.usda.gov/Factsheets/Lets_Talk_Turkey/index.asp</a><br/><br/>HAPPY TURKEY DAY EVERYONE!<br/>
It's all in the quality of the turkey, and you must use fresh. This is the same basic recipe as found anywhere, and has always ended in disaster for me using frozen.
Usually the recommended temperature at which turkey (poultry) is done is 185 degrees. You gave 165 degrees. I found both on the Internet as recommendations. 165 degrees was suggested for meat that is more moist. I have always done ours to 185 degrees and no one ever suggested the meat was dry.
160 is the necessary temperature to kill Salmonella - anything else is bonus/overkill.
It's 165 when you pull it out of the oven, but it will actually continue to rise in temperature when you pull it out.
All of my research showed that 165 degrees is the desirable cooking temperature for a turkey, and it's also what I've always done. As you wrote, logic would support that a turkey cooked to a lower temperature would be more moist, because it wouldn't need to be cooked as long.
nice idea with the butter and herbs! You could add bread, apples and a little cinnamon to make the stuffing taste like savoury apple pie (the taste is kinda hard to explain)
I agree about brining. We started brining a few years ago and the difference is amazing. The best thing we've done is stopped stuffing the bird - no more dry turkey. Not only does it take longer to cook, but the porous bread kind of sucks the moisture out. That's why bird-cooked stuffing is so delicious. But I spent the money on a turkey, so that's what I'm worried about. I always start the bird in a very very hot oven to crisp the skin and then lower the temp with a foil shield on. It's not just for looks, I like a crispy skin when I eat it. And I've never ever basted a turkey, and I've never had a problem. I'll say that this bird looks damn fine, so I'm not going to quibble over particulars. No-stuffing is really the lesson learned here. I put in some lemon, apple, and onion - wet items I think contribute to steaming the inside a little.
Is it food week at Instructables? :D
About This Instructable
211,893views
153favorites
License:
Bio: I've worked for Instructables off and on since 2006 building and documenting just about everything I enjoy doing. I am now the Creative Programs ... More »
More by noahw:How to Send Art Into Outer Space Cómo soldar 意式烤面包食谱
Add instructable to:
