3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SinkScience with the Tesla CD Turbine
For this Instructable, I have tamed the wild beast "PumpkinCutter" CD Turbine of the last Instructable and made it into a fun, smooth and safe kitchen tool that runs on water faucet pressure!
Basic Kitchen Model CD Turbine and Magnetic Coupler.
http://www.youtube.com/watch?v=WFMqPWSpmTY
This instructable will show how to make the experimental Kitchen Model Tesla CD Turbine, made from only CD's, CD Spindle, supermagnets, water nozzle and glue. Powered by faucet water pressure, this model Tesla CD Turbine can actually help with the meals and with family fun. (note: Experimenter's experience may vary...;)
A big plus is that the CD Turbine reuses CD's, millions of which get dumped into landfills, and take 200 years to break down. The Life Cycle of a CD is quite interesting; click here for a cool poster all about this.
The CD Turbine can also be a great way to re-use and re-cycle broken kitchen gadgets. For example, a blender or food processor may have a burned-out base motor. A perfect candidate! ( see step 6 & video).
It's amazing the number of fun games that can happen with a CD Turbine. Yes, it sounds nuts (even to me as I write this ;), but the CD Turbine can even put life into tired old board games! (see step 8 & video) I had a couple of dazzled kids earlier today who were mesmerized by the spinning spinner attachment for the turbine.
Building the basic Tesla CD Turbine has been described in my two previous Instructables.
This design, a Kitchen Model CD Turbine will differ in several areas, simplifying construction. This model is taller, giving a little more torque for tough kitchen jobs...(like salad spinning, blending, or having to stir a mixed drink; all examples I will show...hehe)
The taller size of this CD Turbine also recycles more old CD discs.
Punch Bowl Stirrer...(one heck of a punch...;)
Here is a video of my assistant Rowan using the Tesla CD Turbine as a cool Science Fair project.
Step 1Materials and Tools
Materials and Tools
Materials (Total Cost less than $ 60.00)
-25 CD's (or number to fit your spindle case.)
-CD Spindle, with Cover (one with a thicker base works best)
-Water Nozzle (such as the "Holland Garden House Plastic Power Nozzle")$1.29
-Hot-glue sticks - best ones you can find for plastics. ( about $3.00)
-Super glue and Marine Goop ( a couple of bucks worth)
-12 of 1/2 inch x 1/2 inch cylinder neodymium magnets
(6 for main Disc Pack, 6 for the Magnetic Coupler = 12 total at about $2.25 each = $ 26.80)
-132 of 1/32 inch thick x 3/8 inch neodymium magnets for magnetic disc pack spacers
(6 ea. x 22 discs = 132 magnets at $.019 each = about $25.00)
You can order the BEST neodymium super-magnets from K&J Magnetics here.
Total Cost of Materials less than $ 60.00 (Plus Accessories)
Accessories"
-Blender...........$1.50 Thrift Store
-Bowl................$1.00 Thrift Store
-Spinner...........$1.50 Dollar Store
-Salad Spinner.$5.00 Dollar Store
Total Cost of Accessories = $9.00
Tools
-Hot-glue gun
- Drill (optional)
-Dremel (optional)
- Knife (sometimes)
136 comments
1-40 of 136next »
Sep 22, 2011. 10:51 PMconestogaman says:
Cool gadget if you don't mind the extreme waste of water...
Mar 14, 2009. 6:13 PMSazumo says:
are there any cheaper magnets that would work well? with this? if so, where can i buy them?
Aug 7, 2011. 10:14 AMdfghjzx says:
i found the 1/2*1/2 magnets to be 3.52$ though they may have just upped the prices.
Nov 25, 2010. 11:08 PMKinnishian says:
there's also absolutely no reason for using magnets as the separator...
Dec 6, 2010. 2:04 PMneo-sky says:
you could add blades to make it a puree machine to make salsa,cut up onions,etc.
Nov 11, 2010. 8:15 PMKinnishian says:
WOAH. http://www.kjmagnetics.com/default.asp?PARTNER=mrfixitrick. That's the link you keep linking to. It says partner, so I assume this is a affiliate link. That is 100% ok *If you mention it*, but it is not right to not mention that. People do not know why you recommend kjmagnetics so fervently in your post, and assume its only because they're a great store (and they are, but you're linking an affiliate link- it's widely known not to be kosher not to tell people you're affiliating).
Oct 2, 2010. 2:51 AMriverreaper says:
weres the aultinator an why arnt you powering a lightblub or chargeing a phone with that , or is that class c ?
Jun 11, 2009. 6:17 AMkriogenic says:
Hey there, I beleive I have an explination to why the magnet goes backwards. When the turbine is spinning anti clockwise the magnets spin around with it really quickly, when the magnetic ball is placed ontop since the rotation of the turbine is anti clockwise the repelling force of the magnets is always hitting the magnet on the oppisite side of the forward direction (sorry if that dosnt make sence I tried to draw a picture to explain my result is attached). This is just my speculation and I got some magnets and tried it out i found if spinning a disk with magnets on it really slow the ball would just snap and click onto one of the magnets but if i spun it quick enough the ball would try to snap to the center and be thrown off the back of the magnet and it repeated picking up momentum. -Andrew
Sep 9, 2010. 11:17 AMdarkwolf74 says:
Take a ball and put it on a sheet of paper. Quickly yank the paper out from under the ball and see where the ball rolls.
Same principle.
The force under the ball drives it to rotate in the opposite direction due to the friction on the under side. Once the movement is started, momentum would carry it and cause it to continue around, driven by the counter rotating magnets underneath.
Sep 2, 2010. 7:20 PMquantumkittty says:
what i think: in order for the ball to follow the direction of the magnets they would need to go at a slow enough speed for it to keep up. however, when sped up, magnets pull the ball in the opposite direction. if the ball were a magnet, you would probably right. it's only an iron ball though :\
Jun 10, 2010. 1:24 PMp4trick95 says:
Could this be used to power a centrifuge? To possibly separate sediments? I was planning on making a working centrifuge for a project. Would the tesla turbine spin fast enough to separate cream from milk? Also, would the magnetic couple be balanced enough to not tip over the whole contraption when 2 vials of liquid are place in a bowl at the top?
Jun 10, 2009. 2:36 PMfelixh says:
if you have a broken hard drive that is just sitting around you can get crescent shaped neodymium magnets from the portion that moves the actuator and one could also use the platters in place of the cds also. There is two magnets and four platters usually and the magnets can be snapped in half with a little force
Jun 11, 2009. 10:06 AMfelixh says:
true along the lines of the connecting peace perhaps?
May 7, 2009. 10:14 PMRahdzhillaxxx says:
does adding more turbine blades give you more torque for the same amount of airflow? Or can you just pump in more with the same number. I am curious as to how to maximize the mechanical output. I've always thought of using a wind turbine to pump water to a higher point of my yard and let gravity pull it back down a pipe system through some kind of electric water turbine, that way the energy potential can be stored in the upper container till it is either full or needed. Limited factors are finite space and storage capability.
May 9, 2009. 6:43 PMRahdzhillaxxx says:
I'm grateful for the info. I'm more of the trial and error kind of guy than the do the math and get it right the first 1-100 times LOL My Sister has an ideal spot for this but the most I'd get for height is about 25-30 feet. Then again the energy to get the water up to 100-200 ft would probably defeat any gains. but hey I'm full of ideas and time right now. Thanks again for the info
May 7, 2009. 2:47 AMsollu says:
can it generate electricity
Jan 7, 2009. 8:27 PMcd41 says:
lol kind of funny when you think about it the slower it goes the quieter it gets unlike every other generator
Nov 25, 2007. 8:09 AMu_r_teh_svck says:
whats the point of building this?
Mar 24, 2008. 8:36 AMkillerjackalope says:
I have thought of about twenty viable uses for this in the first six seconds...
Jan 6, 2009. 3:43 PMNetReaper says:
lol, you could use some copper wire and make the top a generator! Make it power some lights or something and still get water!, better than just wasting that pressure
Apr 21, 2008. 12:48 PModie4420 says:
i agree, as a closet cultivator low and effecient energy comsuption is paramount, any thing we can recycle and use for free why not, and why not NOW. U_R_Teh_svck just imagine for half of a second that Y2k would have thrown us into the dark ages, Tesla and his machines are the building block of HOW we would recover from said darkness. While everyone else is rioting the clothing stores and the malls you better be im heading to my local radio shack and other electronic component stores, so that while your defecating in the dark in your brand new nikes im nice and comfortable in my self sustaining house of energy. great instructable MrFixits, keep them coming.
Feb 14, 2008. 5:46 PMsrainsdon says:
or to make a axial flux alternator
Feb 16, 2008. 2:42 AMKa-boom says:
Do i need spacers for a reason or can i just use top magnets or something alternate for spaces.
Feb 16, 2008. 1:33 PMKa-boom says:
Thanks for responding so quickly I don't need to spend an extra $30 now.
Jan 6, 2009. 3:45 PMNetReaper says:
but, if you make it into a generator it could power it's own electromagnets... o.O
1-40 of 136next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
235
Author:mrfixitrick(Mrfixitricks Youtube Channel)
I am re-inventing myself as an inventor, after too many years as a mechanic! I enjoy learning from Tesla disc Turbines, magnetic motors, and Crystal Quantum Radios. "All children are artists. The ...
more »
