Step 2Some Background and Set-up Hints
The water outlet of the CD Turbine is at the bottom of the centre spindle post. What worked well for me was to set the CD Turbine on top of an Airzooka (minus it's plastic membrane), and set the whole works in the sink. The turbine drains directly into the sink, and the water noise level is quieted with the Airzooka around it. Plus, it looks Star-Wars awesome!
Alternately, drain hose connections from the Turbine can go to another water usage area such as a garden or pool, instead of draining directly into the sink. That way, each time the garden is watered, the turbine will rotate (or vice-versa). This remote drain also enables the risky, but extremely rewarding, idea of a SteamPunk Parlour Model or Tabletop Model CD Turbine such as hinted at below.
Keep in mind that this unit, in spite of it's capabilities (which are many...), the CD Turbine is not designed for long-term use. The CD's may de-laminate under wet conditions, the glue may not hold and leaks could develop, the case may rupture with overpressure, etc. I'm still learning best construction techniques to pass on. Stuff can happen. So, no mission-critical endeavours yet, please.
On the other hand it's darn pleasing to make something from almost nothing, that's versatile enough to run many household jobs from just plain water pressure from the tap. And my personal Kitchen CD Turbine has been reliable, leak-free and problem- free for two weeks now of daily occasional use. (so far, so good!)
Free energy! (as long as you don't have to pay for your water, that is.) Even if you do pay for water, there are many situations where the CD Turbine could be run and the water used for it's original purpose...in filling a sink or a swimming pool, for example. It's an extremely adaptable device!
IF THIS VIDEO DOES NOT PLAY PLEASE CLICK HERE
Add Comment
