SinkScience with the Tesla CD Turbine
Step 3How To Build The Kitchen Model Tesla CD Turbine
  • last photo ←
Building this model Tesla CD Turbine is similar to the instructions in my previous Instructables.
However, in this scenario, the turbine might be used in a kitchen or living-room environment, so we need to adapt to the situation. The CD Turbine works easiest draining directly in a sink, where the outlet can run resistance-free to a drain. Plus any leaks get caught by the sink, so using it there makes most sense. We want to raise it off the bottom of the sink, so I used an Airzooka for that. Otherwise, the Tabletop version, removed from a sink, requires extra plumbing, including an outlet adapter and large-size low-restriction outlet hose.
For water pressure, I used a universal faucet adapter to fit the stainless garden-hose to the sink faucet spout. The other end of the hose goes to the Turbine inlet nozzle, which is a hot-glued-on Holland Power Nozzle. (See pics below.)
The outlet hole of the nozzle is a little too big for best nozzle velocity, so glue in a tight-fitting piece of small tubing for better performance. I used a short length of 10 ga wire insulation, and glued it in with crazy glue. Cut it off flush with the case, so that the discs won't hit it when they go around.
Building up the main Magnetic Disc Pack is very similar to the previous Instructable. I started with a "seed" Magnetic Pack with 6 evenly spaced magnets to act as a template for the new magnetic disc pack. I used 1/32 x 3/8 inch magnets to space the plates. That's 6 magnets per plate, times whatever number of plates, to build it up to about 1/8 inch from the top of the CD Case, about 30 discs x 6 = 180 magnets (or less than $30 worth)
The toughest part in making this machine is to glue in the water power nozzle to the side of the CD Spindle Cover. Even this is not too difficult, for I have simplified the process for this model CD Turbine.
Here's what to do about the nozzle: Fire up (that is, plug in) the glue-gun. You're going to use the glue-gun to pierce the inside of the CD Spindle Cover. I'll say that again. You're going to use the glue-gun to pierce the inside of the CD Spindle Cover. there. I said it. So, that's about it. You melt a little hole into the Cover, from the inside, such that the Nozzle can just fit into it (from the outside, of course.) Fit the nozzle in and start gluing. Just make sure that the Nozzle doesn't go in too far as the glue sets, and is at the correct angle. The Nozzle needs to clear the discs inside the case. You should end up with something like below...
Don't forget to drill out the center post of the spindle as shown in my last instructable on basic CD Turbine building.
You can test the unit without gluing the cover on, but it will be messy!
Dry the cover and base well before hot-gluing.
Once the disc pack is rotating freely, then glue on the cover to the spindle base. Work carefully to avoid bubbles which will leak.
Congrats, the CD Turbine should be ready to run!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
229
Author:mrfixitrick(Mrfixitricks Youtube Channel)
I am re-inventing myself as an inventor, after too many years as a mechanic! I enjoy learning from Tesla disc Turbines, magnetic motors, and Crystal Quantum Radios. "All children are artists. The ...
more »
