An aluminum foil reflector oven, coals and a tripod are all that are needed to cook a delicious, moist, Thanksgiving feast outdoors. (no dangerous oil flare-ups here!). Also, included here are instructions for tying a Barrel Knot to keep the turkey suspended off the ground.
This Instructable documents an outdoor cooking method used by our Boy Scout Troop at our annual Thanksgiving campout. This ingenious method of cooking a turkey with coals was taught to us by a venerable "Master" of Scoutmasters, Mr. Martin. I am publishing the technique on his behalf so that others may give it a twirl.
This Instructable is entered into the Homemade Holidays Food Contest. Please Vote.
Remove these ads by
Signing UpStep 1Build the Outdoor Theater (oven)
- 44"x18" Wire mesh
- (4) metal tent stakes
- 18" wide roll of Aluminum Foil
- (4) metal binder clips (office supplies)
- Metal tripod (the one shown is a camp cooking tripod that comes with a round metal grill that adjusts up and down. The grill and 3 side chains have been removed.
- 3 feet of Sisal rope (be sure to use natural fiber rope. Some plastic ropes may melt or not be safe to use with food.)
- (2) Plastic oven bags (these bags are designed for use in household ovens and will handle regular cooking temperatures)
and one more thing....I'm forgetting...uhmm...oh yes the star of the show!
- (1) Turkey (thawed)
Make the 4 Coal Towers ahead of time (they are reusable)
1. Cut a piece of wire mesh about 11" by 18" for the Coal Towers
2. Roll the mesh into a 3 1/2" diameter x 18" tall cylinder
3. Secure the seam on the cylinder by "sewing" it together with a length of thin gauge wire or by cutting a few of the squares along the edge of the mesh and fold them back on themselves "hooking" the other edge of the seam.
Now i know what i'm doing wrong!
I can dig a hole, cut the sheets of aluminum to size, 4 sides and a bottom.
Removable for cleaning...
Ohhh, mommas gonna be mad when she gets home tonight.....
THANKS! This will be good for 'survival' cooking.
In extreme cold we have placed an Alum. foil "tent" on the upper portion of the tripod legs to help reflect the heat to the top of the turkey. But we have never had to totally enclose it by adding a top to the oven "cube".
I like your experimentation with other recipes. Two weekend ago the scouts did the usual two turkeys and only ventured out to add a football ham (without a bag) A little crisp on the outside otherwise not bad.
Please post detail of your recipes. Did you tie up the bass and pork roast or just hang them in the bags?
One 5 pound bass cleaned and head removed
Put sisal rope in cavity running from tail to front of fish
Sprinkle lemon juice on fish’s interior
Put in some pats of butter (near the tail)
Spiral rope up fish’s body to close the fish around the rope.
(Fish should now be hanging head down)
Add 3 tablespoons of water and 3 of lemon juice to bag to add the steam
Slip bag over fish and tie bag around the rope just above tail with string.
Hang from tripod and bake about twenty minutes Any longer and the rope may slide through the fish! (Tender)
Pork Roast (About 3-4 pounds)
Use pork rub to season port roast surface, and tie the roast up like the turkey
Use a 50/50 mix of Worchester sauce and liquid smoke to and brush over pork
Bag the roast, adding a bit of water (3 tablespoons full) tie it to rope
Hang from tripod and give it about 40 minutes (check through the bag with a meat thermometer)
Ham
Prep ham as you like, glaze, cloves, whatever you like
Add water, 3-4 tablespoons to the bag and a tblsp of lemon juice
Tie ham just like the turkey, and bag, tie it tight with cotton string
Bake ham just as you would in a 375 degree oven, and watch it self bast as it cooks! (use a meat thermometer and look for 125-130 degrees internal to know its ready.)
Cooking in a bag with a bit of water inside keeps the meat from drying out and it gives you something to make a great gravy with as well!
Thank you for solving my problem.
Use one tower and hook the aluminum 'walls' to two stakes to form a 'V', the open part towards a lean-to and you could throw a lot of radiant heat into the lean-to and have a right nice camp!
This instructable is first class, thanks for posting it, it has given me several new ideas to play with now!
Adding to your comment about portability....One thing I did not mention here is that if you size each coal tower with a slightly different diameter than the next you can get them to slide one inside each other so that like a telescope, you only end up having to find package space for one cylinder.
L
