This is a device never even intended to make sound at all.
This is a hack in the category of Circuit Bending, but unlike most circuit-bent projects I intend this to be actually used musically, not just crazy noises, although I love those.
These same principles can be applied not only to other Texas Instruments Calculators, but anything that makes sound and has a little brain that you can change the speed of. Changing the "clockspeed," as it is called, will often also change the pitch. Sometimes when set extremely high or low cool crashes and weird noises will occur, especially in toy keyboards.
Remove these ads by
Signing UpStep 1Hardware: Headphone Jack
Not good enough. On mine I opened her up and added a headphone jack next to the linkport. I could have replaced the linkport, but I wanted to maintain compatibility with a normal pc-link.
I also added a tiny speaker that connects to the linkport when a switch is flipped, but the speaker is way to quiet without an amplifier so I don't recommend this. Although if you want to do it this is the chip to use: LM386
comments
Add Comment
Add Comment
