3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn Copper Pennies into Silver and Gold [Chemistry Trick]
video Turn Copper Pennies into Silver and Gold [Chemistry Trick]
In a display of alchemy we turn copper pennies into silver and finally to gold. Obviously it's a chemistry trick but still impressive.
First we get 30g of zinc sulfate and dissolve it into 100mL of water.
Zinc sulfate was made back in our video on making a copper sulfate and
zinc battery: http://www.youtube.com/watch?v=Id3tL2iI0Vw
If you don't have zinc sulfate or can't make it, you can also use zinc chloride. This can be made by simply mixing hydrochloric acid with zinc metal and waiting until the fizzing stops.
Then we drop in several cut strips of zinc metal.
Zinc metal was obtained from our video on getting useful materials from batteries: http://www.youtube.com/watch#%21v=knc1lSupAwQ
The solution is heated to a boil and copper pennies, that have been thoroughly washed/cleaned, are dropped in. They must touch the zinc in order for this reaction to work. Leave it in for five to ten minutes.
The zinc metal dissolves and releases electrons that go into the copper and give it a negative charge. The zinc ions in solution now redeposit form a thin layer of zinc metal. Giving the coin a silvery color.
Now the smart physical chemist might wonder how this can possibly work. Overall we're going from zinc metal to zinc metal and at first it seems like we're missing something about thermodynamics. What is the driving force? I've searched the literature and there doesn't seem to be a consensus among scientists, some claim it's a surface free energy issue with zinc having a lower potential on copper than in free solution (at high concentration). Others state that it's  an alloy of zinc metal and copper on the surface. The silvery color you're seeing on the penny is actually a type of white brass, not pure zinc. This is thermodynamically more favorable than pure separate metals and thus serves as the driving force.
Anyway, whatever the specific chemical reason, we've now deposited zinc onto copper.
The most amazing trick is to turn it into gold. Simply wash the coin and place it on a hotplate heated to about 300 Celsius. As it heats the zinc will diffuse into the copper, forming brass on the surface that looks like gold.
Eventually it will wear off but the results are rather impressive.
24 comments
Apr 13, 2012. 10:48 PMJehnavi24 says:
Zinc Chloride is widely used as application in textile processing, chemical synthesis and metallurgical fluxes.
Mar 11, 2012. 12:14 AMpaullene says:
is the silver coating on the wire permanent? please please i need you helppp
Feb 27, 2012. 2:16 PMOSITOPANDA4MIL says:
hi there. I want to know why the zink around the cupper coin (from the experiment turning cupper coins into gold) turns to gold when you heat it. thanks!!!! :)
Dec 30, 2011. 4:32 PMTheAmateurArtisan says:
(removed by author or community request)
Dec 30, 2011. 4:34 PMTheAmateurArtisan says:
wait... it says brass... shoot. Sorry for being redundant right there.
a side note is that all you have to do is heat most pennies since they are zinc cores plated with copper.
Feb 19, 2011. 10:32 AMElectricUmbrella says:
When I look up zinc sulfate on eBay, most of the results say "zinc sulfate mono hydrate." Does the "mono hydrate" mean anything, and if so will it change the reaction?
Aug 25, 2011. 11:53 AMmattman2 says:
the mono hydrate means it has 1 water molecule in it
Jul 26, 2011. 11:19 PMchemicallypsycho says:
Jul 27, 2011. 11:36 AMchemicallypsycho says:
Its also common knowledge that pennies are not all copper. Is the partner metal also effected by this experiment?
Jul 27, 2011. 7:28 AMchemicallypsycho says:
that was a mediphor... shouldnt the title be named changing coppers color to gold and silver. It looks like your creating nothing more then a copper alloy. Im a huge science lover. Im just looking for new ideas to make cash. I thought ill try doing something that i like.
Jul 27, 2011. 11:28 AMchemicallypsycho says:
is it passable to chemically change a copper element to a gold or silver? Or any other element for that matter. Perhaps by add or subtracting excisting protons Ion or nuetrons? Fussion proccess maybe?
Apr 7, 2011. 6:55 PMgiovibleu says:
Hi Nurd! I don´t undestand about chemistry.
so, do this trick also works with silver ?
or is there another way to get this effect?
thanks!
Feb 19, 2011. 6:44 PMGerrles says:
I cant make the materials because i dont have time , so do u know where i can buy or substitute zinc sulfate and zinc metal
(Im not using the internet for this stuff)
Jan 2, 2011. 7:43 AMDanny574 says:
I've done it with a 30% sodium hydroxide solution and zinkpowder two years ago as christmaspresant.
Sep 25, 2010. 11:46 AMGuppy8 says:
Could this be done with aluminium sulfate, aluminium metal, and copper?
Jul 18, 2010. 10:32 AMmahirh says:
displacement reaction in short thanks!
Jul 18, 2010. 1:43 AMjoosh says:
I did this in my chemistry class for our first lab. Hmm... I still have my lab some where in my lab manual and now I want to go find it.
May 22, 2010. 11:23 AMmikeasaurus says:
neat trick. how long to have the coating wear off and the coin returns to a copper colour?
May 21, 2010. 7:39 AMrimar2000 says:
Very interesting.
I learned to cover with zinc a piece of metal (iron or bronze in my case) using a plastic brush soaked in zinc chloride, connected to the positive pole of the battery charger.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
614
Author:NurdRage(NurdRage)
NurdRage is a dedicate group of science nerds trying to further amateur science with direct how-to instructions in video format. We saw what was already online and we thought "we could do better"... s...
more »
