Introduction: Turn Your Arduino Into an ISP
Learn how to turn your Arduino into an AVR In System Programmer. This will allow you to burn bootloaders onto new chips or program AVRs without a bootloader.
Step 1: Materials
To begin you will need:
* Arduino (I will be using the Uno)
* AVR Microcontroller (This tutorial will cover the ATtiny85 & ATmega644)
* Arduino IDE
* Breadboard
* Jumpers
* Arduino IDE
* Breadboard
* Jumpers
Step 2: Setup
Before we begin programming chips we must set up the Arduino. First, make sure your Arduino IDE is up to date. Then select the File >> Examples >> ArduinoISP sketch and upload it to your Arduino. Now your Arduino is now an AVR ISP.
Step 3: Using Your Arduino ISP: Programming AVRs Without Bootloaders
There are a few instances in which it is neccesary to program microcontrollers without a bootloader. For example, if have run out of storage on a chip you can get an additional 2KB when you program without a bootloader. Another example, the one I will show you how to do, is to program chips that have no serial capabilities and therefore cannot use a bootloader. The ATtiny85 is one of these chips.
To program the ATtiny85 using the Arduino ISP you must first add ATtiny85 support to the Arduino environment:
* Download attiny45_85.zip
* Unzip the folder
* Copy the folder to the Arduino IDE's Hardware folder
* Reopen the Arduino IDE, you should see the ATtiny85 in the Tools >> Board menu
Now connect your Arduino ISP to the ATtiny85 like the diagram below.
Open the Blink sketch, change every '13' to '0', select ATtiny85 from the Tools >> Board menu, and select the serial port that is your Arduino ISP. Now click on upload and your ATtiny will begin blinking the LED once it's done.
* Unzip the folder
Step 4: Using Your Arduino ISP: Burning Bootloaders
What if you want to program your chip over USB without an ISP? Well then you can use a bootloader. The process of programming a bootloader onto a chip is called burning a bootloader. Let's look how you burn a bootloader onto an ATmega644 using your Arduino ISP.
To burn the bootloader to the ATmega644 you must first add ATmega644 support to the Arduino environment:
* Download the Sanguino hardware file
* Unzip the folder
* Open Hardware >> Sanguino >> boards.txt
* Change:
* 'sanguino.bootloader.file=ATmegaBOOT_644P.hex' to 'sanguino.bootloader.file=ATmegaBOOT_644.hex'
* 'sanguino.build.mcu=atmega644p' to 'sanguino.build.mcu=atmega644'
* Reopen the Arduino IDE, you should see Sanguino in the Tools >> Board menu
Now connect your Arduino ISP to the ATmega644 like the diagram below.
Select Sanguino from the Tools >> Board menu, and select the serial port that is your Arduino ISP. Now click on Tools >> Burn Bootloader >> w/ Arduino as ISP. If there is more than one 'w/ Arduino as ISP' just try each one until it works.
* Unzip the folder
* Change:
Step 5: Congratulations!
You now have am Arduino ISP and know how to use it!
