In my case i had my cellphone in my pocket in the rain and it got damp. This is BS in my opinion because water neveractually tocuhced the unit.
All that i suggest you do is put a drop of bleach on the indicator and it will turn from red back to good 'ole white. check out the pics!
Remove these ads by
Signing UpStep 1Below you can see 2 razr phones
on my old phone i left it in the same room when i took a shower and the indicators all changed color, youd think if they can make a phone as small as they can they could make waterlog stickers less sensitive to moisture :P
I had to send my phone back after they sent a replacement due to a back light problem I had. I HAD ZERO WATER DAMAGE, and the sticker was WHITE,
B U T... I am an idiot and did not pay attention when I took the old phone into the kitchen to clean it (it was not filthy but a little funky) and I used a spray mist to dampen the screen and wiped it off. The battery and back cover wasn't on it because I had already put them in/on the new phone and a tiny bit of the mist got on the back/white sticker somehow and it turned red on the edges!
I PANICKED!
I cannot afford to pay for the phone!
LUCKILY I found the stickers on ebay for 1.75, peeled the red edged one off and put on a new white one. I do not feel bad about doing it because the phone truly had no water damage. Those little stickers are hyper sensitive to moisture.
be warned the phone often has 2 water indicator spots, so if you have to send it in, they will likely find the internal sticker is still red. and there is often one on the battery too.
http://www.doli.virginia.gov/laborlaw/laborlaw_faqs_wagep2.html
Read #9
When you first get the phone, take a piece of clear packing tape and cut a round piece about the size of a dime. Tape over the dot. Make sure the tape is completely stuck down (no bubble tunnels in tape).
I have dropped 3 razors and a pantech in toilets and pools (razor kept slipping out of my back pants pocket in the ladies room....).
The second secret - grap out of the water FAST and just as quickly open the phone and dump the battery out. EVEN IF THE PHONE IS STILL ON.
Take the Sim (and storage card out if you have one) and dry with lint free cloth.
open all the ports on phone, then shake it as hard as you can to force water out as much as possible. Then put opened phone in front of a hair dryer, on low heat for at least a day.
You may get condensation on the screen. If you do, continue the hairdrying until it all burns out.
Do not put battery back in and turn on until you are absolutely sure it is dry.
In addition to my accidental drops, I actually 'soaked' my Pantech on purpose. I had spilled a full glass of soda on the phone and could see that liquid got inside the screen & in between keypad. So again, removed the battery, sim/storage cards, put an extra layer of tape over the white dot and soaked the phone for a good 10 minutes in warm water. Shook it around to loosen the sticky liquid. Then followed the steps listed above.
2 of the Razor phones were eventually turned in because the "flip" screw broke.
The Pantech was returned because one of the sliders broke. Each time I was ask if phones had been exposed to water.....
Good as new!
