Step 6Marking the Templates
Since you will be installing the posterboard on the inside, and your templates are on the outside, they must be marked opposite their current position. What is on the left as you face the window on the outside will be on the right as you face the window from the inside.
I've identified mine as shown on the picture.
Carefully remove the templates from the windows and cut them out. Put a template face down (your writing is on the face) and trace onto a piece of posterboard. Carefully cut it out. You can cut it a bit larger for a snug fit. If it's too big you can always trim it smaller. If you cut it too small, it's trash.
On the template, you wrote the location code on the side that faces 'out'. When you finish cutting out the posterboard, write the same code on the side that will face in.
Repeat this for all the other templates you have.
Test for a good fit and tape them in the window.
Add Comment
