Step 3Keeping the curve.
When I began this I was really hoping to be able to simply cut/drill a hole in the top part of the CRT, clean out the inside, caulk the back where the cathode is, and then fill it with water. BOY WAS I WRONG. Long story short, there is a big metal screen inside the CRT and I cracked the glass beyond repair, but who knows maybe I will try again sometime now that I have gotten a better look at the inside of the CRT.
Luckily, after my failed attempt at putting a fairly large hole in the CRT, the front of the tube was still not cracked. So it was up to me and Mr. hammer to get rid of the excess glass.
Once the excess glass has been removed you will need to remove the metal screen. Do not use a grinder to do this like I did. There are metal studs that go through the glass and using a grinder will cause the metal to expand and then the glass to crack. The metal screen can be removed by pressing down and over on the screen support clips.
Now that the metal screen is out the screen needs to be cleaned. I used some WD40 and an old t-shirt rag and it seemed to do the trick. Be careful the stuff on the screen flakes off a lot and is probably not very good to breath in, so wear a mask and turn your shop-vac on to catch as much of the flake/dust as possible.
Next I went a head and put some duct tape around the edge of the glass to soften the edge and keep it from biting me.
cellular decay?= =WTF?!!!!= YOU NEED TO MAKE MORE SENCE!
doint have phd just need to BE A EE!!!!!!!!!!!!!
