Turn Your Smartphone Into a Metal Detector Sensor
25,242
49
7
Posted
Introduction: Turn Your Smartphone Into a Metal Detector Sensor
What Is Metal Sensor....?
A metal detector is portable electronic instrument which detects the presence of metal nearby Metaldetectors are useful for finding metal inclusions hidden within objects such as metal objects buried underground. They often consist of a handheld unit with a sensor probe which can be swept over the ground or other objects. If the sensor comes near a piece of metal this is indicated by a changing tone in earphones, or a needle moving on an indicator. Usually the device gives some indication of distance; the closer the metal is, the higher the tone in the earphone or the higher the needle goes. Another common type are stationary "walk through" metal detectors used for security screening at access points in prisons, courthouses, and airports to detect concealed metal weapons on person's body.
NOTE:-
This app measures magnetic field value using the built-in magnetic sensor that is built into your device The magnetic field level(EMF) in nature is about 49μT( micro tesla ) or 490mG (milli gauss); 1μT = 10mG.
If there is any metal in the area, the strength of the magnetic field should increase. Sometimesthis app used to find electrical wires in walls (like a stud finder) and iron pipes in the ground
Usage is simple: Open this app on your device, and move it around. The magnetic field level will constantly fluctuate. That's it!
The accuracy depends entirely on the sensor in your device. Note that the magnetic sensor is affected by electronic equipment (TVs, PCs, etc.) due to electromagnetic waves.
If this app does not work properly, it may mean that your phone's sensors are damaged, broken or non-existent. To initialize the sensors, point your phone up towards the sky and move it in a figure 8 pattern. Especially, a view cover with a magnet or a leather case with a magnetic snap can cause unwanted results.
DOWNLOAD for android
DOWNLOAD for iOS
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    8 Comments
    i just want some more details
    can u please help me
    Metal Detector and Magnetometer can find metor silver treasure, relics and other magnetic stuff, This app is a working metal detector various Gold and silver using the built in magnetometer by magnetic sensor on mobile and tablet, fluctuations and interferences of the magnetic field. its also work as electric wires and power sources detector .this detecting apps can find medal garret, lilies of the field, this detecting apps is a smart Metal Intensity
    get it from google play : https://play.google.com/store/apps/details?id=com.workingdevapp.metaldetector
    Thank you, very helpful and inspiring.
    http://metaldetectorindonesia.com
    This will only work with ferrous metals. Non ferrous metals (silver, copper, gold, nickle) will not affect the built in magnetometer of your smartphone. Ferrous metals are iron based, which means that they attract magnets.
    obviously
    you can't take this to your yard and search for treasure
    Can you include more details of how you have used this?
