3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn a 1950s wireless into a portable ipod speaker
Step 5Installing parts onto the back
The rear of the unit is a piece of hardboard that has several holes in from previous ports.I blanked most of these off with a strip of hardboard cut to size. Holes were drilled in this piece for amp controls.
I drilled one of the holes at the top bigger and put the cigarette lighter in there.
The switch was wired in near this, which switches the amp on and off, bypassing the original switch on the amp which I removed.
I also mounted my 3.5mm jack coupler on the back too. In hindsight I should have got a proper surface-mounted connector, rather than one that just wedges in. I will secure this with a bit of hot glue and maybe a cable tie or two.
The rear of the coupler, using a jack-to-jack cable, was wired straight to the amp.
Another jack-to-jack cable needs to be carried around with this amp to plug things into it. One could have a wire that sticks out and can't be removed, or maybe a retractable one, like one a ski-pass.
The mounting board with amp attached was installed for the last time in the cabinet, and then I lined up the dials with the bottom of the back-plate. I made markings and drilled them out.
The amp came with some shiny knobs which I have installed for now. It's not hard to replace these knobs with some nicer looking ones if I find some on the bay.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:sladek(All my different online places)
