3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn a Broken Knife Blade into an Expanding Foam Trimmer.
I'm a little bit (cough) OCD so as I built my house if I saw a crack somewhere I filled it with Great Stuff.
I think I used about 300 cans of it and I needed a way to trim it flush since I was using it around all my outlets and doors and windows plus a few places that are probably uncommon to use it like around the 1/2 inch gap I left between my Oak tongue and groove floors and the wall to allow to expansion contraction.
This turned out to be a big time saver later when I was sanding and putting polyurethane on the floors since there were no cracks to collect that fine saw dust that allows seems to get blown around as soon as you begin the finishing process.
Step 1OCD's Throw Little Away...
OCD\
Somehow I had a large meat knife I guess it was with a broken handle. I probably meant to make a new handle for it but I happened to find it just when I was doing a lot of spray foaming and I got to looking at the blade and decided to make a tool from it so I could trim expanding foam flush to a surface and hopefully in a fairly fast manner.
I ended up sawing the handle part of the steel blade of probably with a grinding wheel on edge but I don't actually remember since I bumped my head a while back and seem to have misplaced a few or more thoughts but if I had to do it now I would use a grinder so in all likelihood that is more than likely what I did.
Sorry to Digress...
I found a scrap of angle iron about an 1/8 of an inch thick and about 1" by 1" and sawed a piece off about three inches long.
I lay the blade flat on the workshop floor set the piece of angle iron on top where the shank would normally be and welded it solidly to the blade. I started by just tacking the corners because I wanted it to stay flush and welds can put a twist to your project you really don't want so I tacked the corners and then ran a bead all around and cooled it with a wet rag as I went.
Since I wanted this to be both a lefty and a rightly tool I got my grinder and ground an edge to what would normal be the back side of the knife turning it basically into a dagger. I use my spool sander to get a pretty good edge on it and I ground off the distortion on the opposite side where the weld was made and used the spool sander on that as well to make the face touching the wall very smooth.
I had some odd sized piece of oak laying around and found a piece about an inch wide 2 inches high and about 7 inches long. I use my table saw and ripped a slot in the center of the one inch side about 3 inches long. It took a little fine tuning but I got a good fit on the piece of angle iron with the wood handle, then when I was sure it fit I clamped it and drilled a 1/4 inch hole through the handle and through the angle iron and drove a piece of dowel rod with glue through it.
I drilled a second hole also through the angle iron then unclamped it and added a few more just because and then I used my belt sander to shape the wood handle so it felt comfortable to hold.
I tend to not worry excessively about accidents since I keep having them but looking back it probably would have made more sense to fit the handle, then use the belt sander, then put in the dowels since basically I had to hold onto a sharpened knife handle as my table heavy duty tried to snatch it from my hand so use your best judgment and don't get hurt.
13 comments
Dec 5, 2011. 2:08 PMdeschweinitz says:
You are a creative genious! Thanks for using 300 cans of GREAT STUFF. Please share with us any other stories you have using our product, on our Facebook page: http://www.facebook.com/dowgreatstuff, or connect with us on Twitter and we may send you a free prize.
Marc
Digital Marketing Manager, Dow GREAT STUFF
Sep 27, 2009. 9:08 AMNicola Tesla says:
u sound like my dad
Sep 8, 2008. 1:35 AMGh{O}sT says:
when my house was being built this fat cat lay outside everywhere, it was really weird i'll check if i have a picture
Sep 7, 2008. 12:28 AMlampajoo says:
ROFL, expanding foam rulez.
Jul 2, 2008. 8:03 AMshadowg says:
forget the Instructable I like the dog
Dec 24, 2007. 2:27 PMgamer says:
you love that stuff as much as my dad does,
Dec 23, 2007. 11:55 AMTool Using Animal says:
An instructable on sealing your house would be nice too.
Dec 23, 2007. 3:38 PMTool Using Animal says:
Makes sense, something as large as a home construction would make for an enormous instructable.
Dec 23, 2007. 11:16 AMGorillazMiko says:
smart, i love your dog :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:Senseless
http://senseless.livejournal.com/ I've been attempting to build a house mostly by myself for the last five years... I finally more or less finished it before the bunker project and after recover...
more »
