Turn a Dustbin Into a Smart Dustbin With LinkitONE
10,301
54
5
Published
Introduction: Turn a Dustbin Into a Smart Dustbin With LinkitONE
About: I build products which solve real world problems.
Want to make a cool science project? Want your dustbin to open automatically when you are near to it so you can throw items easily? Then you are at the right place!
Here I’ll show you how to make a basic dustbin that automatically opens up when any kind of motion is detected.
Step 1: What Do You Need?
1 . LinkitONE board
2. Servo motor
3. Breadboard
5. PIR motion sensor
6. Battery pack
Step 2: Looking Into the Dustbin
Look into the dustbin and see that where can you fix a motor that opens the head of the dustbin. I found a foot-opener and I’ll attach the servo motor there.
Step 3: Assembling Up the Servo Motor
Now assemble your servo motor as shown in the images.
Carefully do it so it is permanently tight enough.
Step 4: Attaching Motor to the Dustbin
Now attach a servo motor to the foot-opener of the dustbin using a servo motor. When the servo motor will rotate, the dustbin will automatically open its cap.
Step 5: Attaching Motion Sensor
Now attach the PIR motion sensor to the dustbin just as shown in the image.
Pin connections: PIR to LinkitONE
VCC – 5V
DATA – D8
GND – GND
After this we’ll write some code for the sensor that activates the motor when motion is detected!
Step 6: Writing Some Code
The code is really simple here!
We just need to read the motion sensor, if the motion is detected, the servo motor will start.
CODE:
#include
Servo myservo;
void setup() {
myservo.attach(9);
pinMode(8, INPUT);
myservo.write(90);
void loop() {
if(digitalRead(8) == 1)
myservo.write(90);
else
myservo.write(0);
delay(250);
Step 7: Finalizing It!
Now attach the board to the dustbin tightly and finalize the project!
Check for all the connections that they are correct.
Once done, you are ready for testing!
Step 8: Now Test It Out!
Take a balled-paper near dustbin and see it open up automatically!
Congrats! you've made your own smart dustbin!
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    5 Comments
    can i use adruino
    can i use also arduino?
    Nice job,.
