So, first, What I had was a broken laptop. I tried to use the screen as a normal lcd screen, but it wouldn't work. So I thought I could turn it into something more...useful.
What you need :
- A laptop (hm...broken) or a laptop screen.
- A small cross screwdriver (check the photos)
- A bigger flat screwdriver (actually you could use anything like a knife, as it's not meant to screw here)
- A cutter knife (maybe a thin knife will do)
- A small box (better small boxes) or a glass, to keep the screws
- Approximately 1 hour
Read the whole tutorial before starting, you may want to jump or invert some steps depending on your way of working, or on your equipment.
Now let's get started.
/!\ This instructable doesn't imply cracked screens, it is safe as long as you don't break yours in two, which would require a strong hit. But be careful, as commented S1L3N7 SWAT, "most laptop displays have a small, but still dangerous amount of Mercury in them. It's usually contained in the lamp portion." That means if your screen is cracked, or if you crack it, take it to a recycling agency and be careful about yourself.
Remove these ads by
Signing UpStep 1Step 1
So, first take off the small plastic masks over the 4 screws in the corners of the screen (Photo 2).
Then just unscrew the 4 screws and keep them safely in a small box/glass (Photo 3). Now here's what we've got (Photo 4).
Effectivement, une extension multi-langues serait un gros gros plus pour ce site déjà énorme (figurativement parlant)...je penserai à refaire l'instructable en français ;) mais probablement pas tout de suite...
http://solarfilmco.com/mirror-window-film.html
The screen will act like a mirror when in direct sunlight and when the screen is off, but when you're using it normally, the image should shine through.
This is how those hidden-screen phones work, that have a mirror surface, but then characters can show up underneath it somehow...
http://answers.yahoo.com/question/index?qid=20060923202508AAKhUd3
