Well with this magic system you can play all your favorites on a 4-player system that uses authentic Super Nintendo Control Pads. It has the capability to play games from NES, Super NES, N64, Neo Geo, Gameboy Advance, Commodore 64, Sega Genesis, arcade games and more! It is cartridge free, and plugs into any TV with HDMI. Take it to any friends house, because this puppy is very portable! The secret is there is a mini computer inside of the Super NES that runs whatever classic games you choose.
I started with just an old Super Nintendo, and with about $200 and some time on my hands, I was able to turn it into pure gaming gold. You can do the same thing as well, just follow this instructable!
This console is:
• 4 player and super portable - have a gaming party at anyone's house!
• Cheap to build
• Able to use authentic SNES controllers (4 player with additional wireless controllers.)
• Solid State, no moving parts
• Cartridge-free! Store all your games on a SD card.
• Can be used in Modern TV's even if your real Nintendo is cannot be accepted by your TV.
• Going to make all your friends jealous ^_^
Check out a demo of the player right here:
The emulators I use are all 100% free. Keep in mind if you build your own player, it should be used for games that you legally own.
Remove these ads by
Signing UpStep 1: Everything You Will Need
• Basic soldering skills
• A bit of computer know-how (Installing operating systems, emulators, tweaking computer settings)
• Some Mechanical know-how as well (Putting together computer components)
Here are the tools you will need
• Screwdriver set
• Glue gun
• Soldering gun, solder removal gun
• A thin 4mm socket (for removing those pesky Nintendo screws)
• A cresent cutter.
• SD Card Reader
• Keyboard and Mouse
Here is the parts you will need, see the photo for details on each item below:
• An old Super Nintendo with controllers
• A mini ITX Motherboard with processor (Must have HDMI output, have an external power supply, and must be no more than 4 cm high) I personally used a ZOTAC IONITX-C-U. The nice thing about the Zotac is that it does not get hot enough to need a cooling fan.
• Stick of RAM for the computer
• SD Card SATA Solid State Hard Drive
• 16 GB SD Card (goes in the solid state drive)
• USB Super NES dual port controller adaptor
• HDMI Cable and HDMI adaptors
• 2 Cherry microswitches
• Some standard internal computer cables
• Some wire and solder
• (Optional) 1 or 2 wireless dual shock style controllers if you want 3-4 players (These are also needed to play N64 games)
• Speaker grating for cool ventilation.
• 4 philips head 1/2 inch machinery screws for putting everything together.
• Windows XP or other operating system
Visit Our Store »
Go Pro Today »
is there enough room for a ssd where your sd to sata adaptor is?
it seems to be quite hard to find mobo's with a cpu and psu for $100 right now...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157228
Is the one I am looking at using for my version of this.
Another great site, albeit UK based, is http://www.mini-itx.com/store/boards
They have boards, accessories, and even 12VDC PSU
Keep Rockin' dude!, thumbs up!
I call bullshit
there is only 1.38mb on my sd card now???HELP???
On another note, could you use the original power switch of the snes? If not, is it a matter of space, or compatibility?
As far as the switches go, I could not use the power switch because it was a hard on off switch. Computers generally use a momentary push switch for their power button. The reset switch on the Super NES is a momentary switch, so I probably could have used that though. I am guessing that just about any switch that springs back to the off position should work.
do i do it on the snes or my pc?
Do you think it's possible to do the mod with a PAL console also?
I believe that a PAL console could possibly work, they were similiar size consoles. I think the US Super NES was a tad taller with it's "hump" in the middle though. I didn't make much use of this area, but certain motherboards have a taller heatsink that could possibly need that clearance.
Sorry about the slow reply, I haven't been around computers much these days. Yes, dos box should run fine with this sort of setup. The only downside is many dos games might have a hard time mapping to a joypad. You can always work around this by using a program like xpadder or joy2key that will turn gamepad controls into keyboard strokes. xpadder also maps mouse controls as well I believe.
RAM chips are basically over flow for a computer's hard drive. RAM chips provide extra memory (Which is mostly temporary) that helps relieve your hard drive's workload when you have a whole bunch of windows open at the same time. The extra memory makes your computerr run faster and allows you to run more windows at the same time without having your computer poot out.
Ram is what makes machines run fast, by accessing memory from the stick; it can load a saved file.
It's not a USB type of stick, it's more like a microchip. Buy one on Ebay or something,
And then you run a emulator on it
Am i right?
WITH THE SD CARD
links???
I WANNA MAKE THIS BUT THERE ISNT ENOUGH DETAILS
First, it is small, portable, and HDMI plug and play ready. With a computer, you generally have a larger tower or case that may not be that easy to set on you TV stand. You also need a computer with HDMI output. If you set a computer up on your television, you generally need to use keyboard and mouse to access each emulator, which can be a big hassle. With this project, everything is booted directly up into the menu and ready to use. You also can't easily bring your computer over to use at someone else's house or even a different TV without the hassle of carrying the tower, keyboard, mouse, and whatever you want to plug in and set up for controllers. I have brought my Super NES over to friend's houses with everything fitting easily inside a satchel. The system is very light as well (2lbs, 8 oz).
Another perk is that most people want to use real controls for their classic games. This uses official Super NES controllers, which were similiar enough to the NES style as well.
It also has a nostalgia wow factor as well. Going to a friend's house lugging a computer over and setting up an emulated game is not as fun as just bringing over the super nintendo, flicking it on, and start playing classics. Since this is solid state hardware, you won't even have the hum of fans going.
Cheers!
and this one and you have a portable PMGS (portable multi game system!)
just a thought also make a video out and make it HDMI (i'm terrible with HDMI stuff) again sorry if this is off topic
this thing is sweet!
I believe the PS3 controller software is called Motion Joy. It can be a bit of a pain but works great. (also works with USB plug) http://forums.motioninjoy.com/viewtopic.php?f=3&t=1186
A Wired 360 controller will work as well and is supported by microsoft. (get the latest Direct X)
If you have an Xbox original controller they are super easy to hack to USB, Simply Chop off the plug and splice it to a USB cable. Then use the XBCD drivers which can be found here. http://www.redcl0ud.com/xbcd.html
another option, which is what i currently use for PC game controllers, is the Fusa Gamepad for custom firmware PSPs, it enables your PSP to be a PC game controller and ive found that it works quite well.
Thanks.
An option for a board without an onboard DC output would be to buy a PicoPSU. These are small DC circuits that will connect your mobo to a laptop power brick. The PicoPSU new will cost you about $25, and a power brick new can cost you another $25. The Pico is very small though, so it should be not take up much real estate in your machine.
also is this mobo appropriate for this prj?am kind of a noob at this stuff for now;p
http://discount-cabin.com/shop/product_info.php/zotac-gf9300-lga-775-nvidia-geforce-9300-hdmi-mini-itx-intel-motherboard-p-105567?currency=GBP&osCsid=bcca8084ffadcfce747191afae8d5297&osCsid=bcca8084ffadcfce747191afae8d5297
thanks
I would personally recommended checking eBay for a cheap copy of XP, just be sure to get one that comes with the validation code. I see some now that are currently going for $1.00, I'm not sure how much the bidding would go up on them though.
You can also try installing Ubuntu, which is a free to download Linux operating system. I is suppose to be easy to install and use. I tried once and gave up though.
I am not going to advocate piracy either, but if you do download a copy of XP with a serial off of some torrent site, there is a chance that it is not necessarily illegal. I am no legal advisor, so I could easily be wrong though. It is my understanding that if you bought a computer that came bundled with XP, a lot of times those copies come with securities that keep you from using the CD on a different computer if your first one breaks. You still purchased a 1 legal license to that version of Windows XP, and have a right to that version of Windows XP, even if you can't use your original disk. As long as you only use the 1 copy of windows XP at a time, you are not violating your 1 purchased license. The downloaded copy of windows XP would qualify as a personal backup.
I'm not trying to open a debate on license laws, so I just recommend checking eBay for a cheap copy of XP. :)
PS, I can't help but love the milk cap button you made! Very clever button you Macgyver'ed together!
I have a Windows XP Professional disk that I salvaged from the IT department of my old school, and never bothered to use it, so I might go grab a serial somewhere and use it for this (if I ever do)...
PS, my milk cap button is nothing compared to a SNES All-in-one gaming system. Just sayin'. :P
By the way, thanks!
I've had gameboy games be so overplayed they just stop working. And not being rough, at all.
Xbox/Gamecube were the last generation of reliable consoles, and they won't last another 10 years like the SNES did.
Emulation has come a long way! :)
A super NES is by no means a rare system, there are millions of them around, and re-purposing a broken one only respectfully adds new life to something that was otherwise dumpster bound.
You can also still buy super nintendo's brand new. They are off brand, but they are still being produced.
There is nothing rare nor valuable about a super nintendo.
Also, look at the video or read the text, those are not PC games being played.
Pretty much it must meet these three criteria:
Have HDMI output
Have a external power supply, like a laptop
Be no more than 4cm tall. This height might be able to be fudged a little if the height is all in the center taller area of the Super NES, where the cartridge slot is.
If anyone has any suggestions, I please share! :)
The supplimental PDF for installing XP on a SD to SATA drive on the bottom of step 6 should be something that you can download.
There is also an appendix on the bottom of step 8 that you should be able to download as well. Let me know if you still have trouble with these files.
Thanks
and is this your design???
Love the project and idea :)
No matter what, it's good to put out there that Linux is a very good option for anyone interested in make something like this! Thanks!
If I build one will it help me get a girlfriend?
You just have to learn to impress women with this machine's capabilities. Let her know that your Super Nes holds over 18 Mega Man titles, has the ultra rare, unreleased in the US, Secret of Mana 3 and then finish up by letting her know it is all completely solid state hardware under the hood. She will be all yours, dude!
My last bit of advice is that women love the game "Altered Beast"..they go crazy over it. It must have something to do with those Twilight books. Tell a girl that you would like to spend the evening collecting power orbs with her so that you can transform into golden werewolves and storm Neff's palace. She will know what you mean! ;)
I haven't pulled out those machines in years, although a game of Tecmo Super Bowl sounds great right about now. I'd gladly sacrafice an old shell to be able to play these classics in style. Of course you could play these on PC, but the point is - how cool is it to have everything assembled in an old SNES!! That's not only style, but all the classics at your fingertips. Anyone who loved these systems should appreciate that.
http://www.virtualvillage.com/wireless-dualshock-usb-gamepad-for-pc-2-4g-C07400-075.html?utm_source=googlebase&utm_medium=shcomp
I don't specifically remember where I got the microswitches from, because I collect arcade parts. You can just do a google search for "cherry microswitch" and there will be quite a few options. I noticed some for sale on ebay. It would cost me $3.60 after shipping for 2 switches.
http://compare.ebay.com/like/140480934209?var=binlv<yp=AllFixedPriceItemTypes&var=sbar&rvr_id=223817462545&crlp=1_263602_324952&UA=WXS%3F&GUID=965aada912e0a47a4480fe90ff25e0d2&itemid=140480934209&ff4=263602_324952
Also, could you possibly use four wireless controllers instead of the original controllers? I prefer the classic feel, but I was curious if it was possible.
And where could I find those computer case wires for the power switches? I don't entirely know what it is they are called, and I dont have any cases that are unaccounted for, so I'm at a loss when searching for them.
As for the computer case wires, I personally just pulled from an old computer case, but you can buy them new. This link has a kit with wires for the power switch, reset switch, and LED lights:
http://www.ecost.com/detail.aspx?edp=44678374&source=EWBBASE&cm_mmc=CSE-_-google-_-ewbbase-_-Computer&CAWELAID=366991383
http://www.amazon.com/SNES-Controller-Adapter-USB-Super-NES/dp/B002IXZ5DE/ref=sr_1_2?ie=UTF8&qid=1301635297&sr=8-2
How much do you charge to send me a similar "console" to Mexico?
Thanks.
Thanks!
Vigo the Carpathian
Wouldn't booting straight to a USB Flash Drive give you better speed and bypass the cost of the SD-SATA adapter? I was under the impression that most modern BIOS could be set up to boot from USB instead of a real HD..
As for speed, I thought the SD card would be faster since it connects via SATA instead of USB. I could be wrong, but I was very pleased with the speed; it can boot up in under a minute and load games quickly.
No matter what, I'm sure a USB drive would work great if the motherboard accepts the drive.
I'd need access to the board to figure out how easily you could boot from USB - you might need to switch to a more live-friendly OS like Ubuntu to get the whole thing working. The only real loss by switching to a different OS is you'll need a new front end.
I have personally installed Windows and Ubuntu on a flash drive for a couple computers, but I still wasn't able to get it to work on this motherboard. It did seem to have USB booting options in the BIOS as well. It probably just user error in this case, haha!
For anyone planning on doing this project, you can probably use a USB drive just fine, and even squeeze in some better speed - however, my method does get satisfactory speeds for booting up and running the classic games.
as for speed, I can't imagine any of the media mentioned would become a bottleneck. I don't think any of the systems being emulated could go too fast for them.
Don't get your hopes up for PS2 games, though. Not only do the disk images take up a ton of space (you'd need either a real HDD or a DVD drive), PS2 emulation is still fairly terrible (especially on a budget computer like this one).
For that cost you could probably build an even better desktop too, but as the netbook itself fit in the snes case, and it is battery powered, it could make another interresting hack. A snes with a screen =-)
