Step 3Put Together the Controller Port
1) Open up the adapter by removing the screw from the bottom.
2) With a desoldering iron, remove the solder points from each pin of the controller port. The ports should come off. There will be 7 pins for player 1 and 7 pins for player 2.
3) Take the controller port from the Super NES. On the back side will be a green circuit board. Desolder the two rows of 7 pins and the green board will come off.
4) After you take the green board off, desolder the red LED light. This can be attached to the computer later as it's power light.
5) Solder 3-4 inch wires to the leads on the SNES port.
6) Keeping the wires in the same order as the pins on the USB adapter, solder the wires carefully to the adapter circuit board. Each player has a section of 4 leads, followed by 3 leads.
7) Hot Glue the circuit board on the groove of the Super NES controller port. Also, the red LED gets placed on the port as well after you have soldered some computer case wire to it.
Add Comment
