Turn a TI Graphing Calculator into an Intervalometer and Create Time Lapse Videos by yonderknight
Featured
I've always wanted to make time lapse videos, but I don't have a camera with an intervalometer feature built in. In fact, I don't think very many cameras come with such a feature (especially not SLR cameras).
So what do you want to do if you want to make time-lapse videos? You can buy a commercial intervalometer (yeah, right). You can check out some instructables like this one and make one yourself out of electronic components.
But what if you don't have the time/skills necessary to build one? You just want something quick and cheap.
Well, you can actually use a common TI graphing calculator (I don't know of any high school student without one of these) and hook it up to any camera with a remote shutter release socket. It's quite easy, and depending on your camera can require no electronic work at all.
Step 1: Parts Needed
Here's a list of parts you need:
A TI graphing calculator - I'm using the TI-83+. I haven't tested my code on any other model, so I can't guarantee it will work.
Camera with remote shutter release socket - I'm using the Canon EOS Rebel. This has a 2.5mm socket that you can use to connect to the calculator. If your camera does not have a 2.5mm shutter release socket, you will need to create some sort of link cable that can connect the two together.
Link Cable - If your camera has a 2.5mm socket, you can use the link cable that should come with your calculator.
1-40 of 265Next »
softenersreviews says: Mar 2, 2013. 3:45 AM
Loved it. The theme, the climactic and triumphant ending. Absolutely brilliant. I smell an Oscar!
Otterblue says: Sep 18, 2012. 6:52 AM
Wow! This is great! Thank you so much!
kbaker18 says: Mar 23, 2012. 5:59 PM
Can this be done using the Nikon D3100? Can the calculator be hooked to the Nikon D3100 and used as a intervalometer for a time lapse film?
abhinav777 says: Aug 24, 2012. 12:48 AM
As long as your camera has a 2.5mm or 3.5mm remote shutter trigger, this will work. I do believe the 3100 has the port, but I am not certain.
botunkus says: Sep 10, 2012. 1:01 PM
Can't get this to work with a Canon 30D or 40D even though I have adapted the 2.5 mm plug to fit the canon trigger that goes into the camera. Will this only work with a Canon Rebel?
abhinav777 says: Sep 10, 2012. 3:41 PM
The N3 connector type is identical to the TRS connector in terms of wiring. Only the shape is different. It should work just the same. I'm not sure why it's not working on your 30 or 40.
Philosocrates says: Sep 2, 2012. 2:21 PM
Does anyone reading this know how to program a Casio fx-9750Gii to do this? I have tried every variation in the posts but I get a syntax error every time.
addisonh11 says: Aug 26, 2012. 10:18 PM
My TI-84+ didn't come with one of these wires. Does anyone know of a website or store i can buy the right wire from if I want to do this? thanks :) I'm so excited to try this out
Snoopy101x says: Feb 19, 2012. 4:22 PM
I know this is sort of an older instructable. I have a Nikon D3000 and a TI-89 Titanium, and I have yet to get this to work. If anyone has any advice I'm all ears.
Thanks ahead of time.
TechDan says: Feb 15, 2012. 7:11 AM
I used this method just a back in 2009 to make a time-lapse plane construction video over a weekend. http://www.youtube.com/watch?v=QjARFrVcRKM&feature=plcp&context=C39b2812UDOEgsToPDskLvuiKUi0c_6WJh8JoTfJs0
I'm about to use it again for a new plane. Helps a lot with illustrating construction techniques for new students.
brodgers1 says: Nov 26, 2011. 1:18 AM
Okay, looking at the code, I'm a little confused by this line:
For(H,1,A,1)
What is H? And if someone has previously set H to represent a number, would it mess up the program?
mpilchfamily says: Feb 7, 2012. 9:47 AM
The For() statement sets up a loop. The "H" in this case is the variable the For() statement uses to store the number of passes the loop has made. The next variable designates the number to start with. The "A" is the number of loop that have to be made before the program moves on again. The last variable is how much the counter progresses after each loop. So H is set and zeroed out each time the For() statement starts. Check your manual for more details about the For() statement.
silentfallen says: Apr 25, 2010. 2:16 PM
After playing some with the program setup you gave .. i liked it but i didn't like the fact that i had no choices.. So i made my own.
If you are interested give it a try..
( the % are supposed to be arrows.. the STO key above on/off)
Disp "START DELAY IN"
Disp" SECONDS"
Prompt A
A*333.3333 % W
Disp "HOW OFTEN IN"
Disp "SECONDS"
Prompt B
B*333.3333 % X
Disp "HOW MANY SHOTS"
Prompt Y
For(H,1,W,1)
End
Send(A)
Y-1 % Y
While Y>0
Y-1%Y
For(H,1,X,1)
End
Send(A)
End
As you can see from what "solupine" showed.. you need to multiply your delay (seconds) by approx. 333.3333 to get the camera to fire at the right time...
The first delay , is how long till it takes the first shot.
The second delay, is how often between shots
This was done on a TI-83+ , if you try it on other models post it up if it works or not please..
karanbhvsr says: Jan 21, 2012. 4:00 PM
You sir, are a genius! OP's program didn't work but yours worked flawlessly (so far). Thanks to instructables, I've built an intervalometer and a shutter release for less than $20! (Calculator doesn't count :P)
walamoonbeam says: Dec 17, 2010. 5:55 PM
I'm assuming the answer is no, but sometimes there are spaces between the % in your instructions and other times there are not, so were those spaces a typo? Or do you actually need to include them.
silentfallen says: Dec 18, 2010. 8:10 AM
its been a while since i have played with this but i think you dont have ot have the spaces in there.
Frnc11 says: Sep 16, 2010. 8:49 AM
Do you replace the items in quotes with the value you want or should I enter it as shown? As in Disp "HOW MANY SHOTS" or Disp 24?
silentfallen says: Sep 16, 2010. 9:36 PM
Enter the program how it is writen above with the % replaced with the STO key (above on/off) and run it .. the Disp lines are just text outputs so you know what to input .. for the how many shots one for example the Disp"HOW MANY SHOTS" is the text question for the line below .. Prompt Y ..
to understand it the best i suggest putting it in as i have it above and running it .. it will explain itself..
Frnc11 says: Sep 22, 2010. 9:02 AM
The program seems to run fine. No hickups or syntax errors, however, my camera refuses to fire the shutter. I have checked and re-checked the code for any flaws, but have yet to find anything. Any suggestions on what might be causing this problem?
silentfallen says: Sep 22, 2010. 7:26 PM
what type of camera are you trying to fire??
Frnc11 says: Sep 22, 2010. 10:23 PM
I've tried an XTi, Rebel 2000, and Rebel G. Same results.
Frnc11 says: Oct 5, 2010. 11:01 AM
The program WILL fire the shutter. As it turns out, the shutter button needs to be pressed halfway down to allow the camera to meter. Is there a fix for this? As in, a way to program the calculator to automatically meter prior to taking the shot?
silentfallen says: Oct 5, 2010. 7:20 PM
ah yes i should have added that i guess. you need to be in Manual Focus to make this work without pressing the shutter down half way. I am not sure if you get program the calculator to do both.
I my self do not have the spare time anymore to reprogram it to see if i can get it to work. if anyone out there has any ideas on how to program it please feel free to post it.
silva_pedro says: Jan 5, 2012. 3:42 PM
Somebody has some idea or recomms for the same project but using HP48GX+ and Nikon D100 ?
The Insomniac says: Jan 2, 2012. 1:26 PM
Any chance this would work with a Nikon D40? It doesn't have a 2.5mm socket, but it does have a USB mini port that can be utilized, assuming I had the right cable. Thanks!
scoutx says: Dec 10, 2011. 4:39 PM
Great work
Used my Ti-83 and Canon 1000d ( Rebel XS)
tylercard says: Nov 2, 2011. 8:35 AM
Great work
Wally_Z says: Sep 15, 2011. 2:46 PM
I have written a few programs for my TI-84+ Silver Edition. Most of the programming is the same for the TI-82, TI-83, TI-84. I haven't done anything other than write simple conversion programs. If anyone can find me a link or something to more advanced programming for the TI-80 series I will be eternally grateful. If you want a few programs I made, message me.
cgoldsmith3 says: Sep 21, 2011. 6:01 PM
Can i have the codes for the ti-84 silver edition????
zx3fred says: Oct 28, 2011. 4:59 PM
Bumping from below------------------
From Luberack (Mar. 10, 2011)
I also used silentfallen's program below. Very nice! I did notice that the timing seemed to be a bit off, so I ran the program at various times in front of a stopwatch. I put the numbers in Excel and got the slope of the linear trendline that tightened up the timing tremendously. Here's the scale factors you should use for the TI-84 Plus (not sure about others):
[note: "%" should be replaced by pressing the "STO>" button.]
A*750.64 % W
B*750.64-704.12 % X
So here's what the whole program will look like:
Disp" SECONDS"
Prompt A
A*750.64 % W
Disp "HOW OFTEN IN"
Disp "SECONDS"
Prompt B
B*750.64-704.12 % X
Prompt Y
For(H,1,W,1)
End
Send(A)
Y-1 % Y
While Y>0
Y-1%Y
For(H,1,X,1)
End
Send(A)
End
hit "QUIT" to save and exit programming
Wally_Z says: Sep 21, 2011. 7:26 PM
So you would like the coding for some programs I wrote?
Madrid2001 says: May 4, 2011. 3:37 PM
In the TI-83+ I
1) Turn on your graphing calculator (duh)
2) Press the PRGM key
3) Press the Right arrow twice to highlight the tab at the top titled "New"
4) Press ENTER
5) Enter in a name (I used "Camera")
In the step 6) I Pressed program, but does not appear Prompt . Can anybody Help me.
Thanks,
R.Gil
zx3fred says: Oct 28, 2011. 4:46 PM
Prompt is found by pressing PRGM -> tab over to " I/O " then scroll down to "2:Prompt" -> "Enter"
Madrid2001 says: May 4, 2011. 4:03 PM
How do you put Send (A)?
H and A mean?
Thanks,
R. Gil
zx3fred says: Oct 28, 2011. 4:43 PM
PRGM -> (tab over to "I/O") -> scroll down to "B:Send( " -> " A " -> " ) "
luberack says: Mar 10, 2011. 9:47 AM
TI-84 Plus Silver Edition, and Canon EOS Rebel T1i:
I had modify the cable to make it a "cross over" cable. Assuming Tip is #1, Middle is #2 and Base is #3:
1 2 3
X |
1 2 3
So, Tip "crosses over " and connects to the Middle on either side. Base remains a direct connection.
Camera also has to be in Manual Focus mode (usually a switch on the lens).
Otherwise, when triggered the camera will only "half press" the shutter. So you'll hear it autofocusing, but not releasing the shutter. Using the Cross Over Cable and the Manual Focus fixed the problem.
A*750.64 % W
B*750.64-704.12 % X
Disp" SECONDS"
Prompt A
A*750.64 % W
Disp "HOW OFTEN IN"
Disp "SECONDS"
Prompt B
B*750.64-704.12 % X
Prompt Y
For(H,1,W,1)
End
Send(A)
Y-1 % Y
While Y>0
Y-1%Y
For(H,1,X,1)
End
Send(A)
End
hit "QUIT" to save and exit programming.
zx3fred says: Oct 28, 2011. 4:36 PM
Works perfect! Thanks for the post. I use a 2.5mm (male to male) stereo cable for mine. Radio Shack has them, if not use a 3.5mm stereo cable and two adapters to get the 2.5mm ends.
luberack says: Mar 10, 2011. 10:05 AM
ASCII diagram above didn't look so good, so here's a picture of the Cross Over Cable.
gobproperty says: May 6, 2011. 10:10 PM
Do I need to buy a audio 2.5mm jack and then reverse the "tips"--like go to Radio Shack or Frys to do this? This will be a cosmic egg--an attempt at electronics way beyond my comfort level! Can't wait to try it.
for now my Sony A200 is almost nonresponsive--the menu screen activates, but does not trigger the shutter. should this "cure" this issue?
plegendre says: Sep 28, 2011. 4:14 PM
Can I use this standard code also with my Pentax DSLR ? Model is Pentax ist DL2 :)
1-40 of 265Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
