3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn a Trackpad From a Broken Laptop into a PS/2 Mouse
A friend gave me a broken HP Pavilion laptop. With just a little work, you can remove the trackpad and connect to a PS/2 or 9-pin Serial port . Connect to your PC and use as a simple mouse, or even wire to an Arduino for a unique interface for your project. You can make this project entirely from recycled parts you may just have lying around.
What you need:
-trackpad (I used a Synaptics TM41PUZ307)
-male PS/2 connector with cable (or a 9-pin serial)
-multimeter
-soldering iron
-screwdriver
-razor blade
-electrical tape
Step 1Remove Trackpad from Laptop
Unscrew all the parts to the trackpad. Gently pry up any plastic. I used a hair dryer to help loosen the glue that held the pad to the laptop palm rest.
24 comments
May 10, 2012. 2:54 PMyaly says:
Mine is TM-00372-011 I need pinout quick
May 10, 2012. 3:29 PMyaly says:
please PM me
Oct 2, 2011. 3:40 PMdidgitalpunk says:
like recordmasta001 said, how do you right clik? but first of all, is it even possible to right click?
and for my own trackpad, i used a usb-B connector(went on pinout.ru and search for the usb connector page)
and i got help from this instrutables(thanks Jamby):
http://www.instructables.com/id/How-to-build-your-own-USB-Keylogger/step3/Solder-First-Zone/
Apr 6, 2009. 6:45 PMhg341 says:
hum... any idea on how to do usb?
Jan 4, 2011. 4:19 AMFodaro says:
I believe that to adapt PS/2 to a USB port is a simple matter of connecting different pins of the PS/2 connector to pins on the USB plug. http://pinouts.ru/InputCables/usb_ps2_mouse_pinout.shtml looks like it's got a pin-out for it.
Dec 21, 2010. 8:32 PMKasm279 says:
Some trackpads are USB, depends on the model, but most aren't. Only one I can think of is the MacBook line's trackpads.
Apr 7, 2009. 12:11 PMhg341 says:
hum i have a usb to ps/2 to din!
What model of HP laptop was that? Let me guess, death by overheating?
Sep 13, 2010. 12:09 AMzapskate says:
i don't know for sure but ctrl click should work!? try it out
Jun 29, 2010. 8:44 AMrecordmasta001 says:
how do you right click though?!
Jul 24, 2009. 7:04 AMetsitservice says:
I like the idea, but where's the buttons? I understand that the actual touchpad unit does not contain mouse buttons, but how would they be added? Could I piggyback onto an old mouse for the button functionality?
Jun 20, 2010. 12:41 PMduckythescientist says:
On my mouse pad, the ribbon cable has 6 connectors: power, ground, data, clock, and two for buttons. The mouse pad may not have buttons on it, but it probably has the inputs for buttons. (On mine, the button lines are designed for buttons that short pull up resistors to ground. The lines are also protected by double diodes that clamp stray voltages to the power and ground lines.)
Sep 4, 2009. 9:44 AMfreerunnin1 says:
if you enable the number pad as a mouse can be done in control panel> accessibility options> mouse> use mouse keys then the 5 button will be left click and the button next to right ctrl will be left if he wires it up so he has extra buttons on the touch pad then it will be like a propper mouse :D
Mar 31, 2010. 4:55 PMcomsa42 says:
You could also bun the cable on some models
Jun 25, 2009. 10:17 PMf86sabre says:
from an old mouse, otherwise the colors do not match
Apr 19, 2009. 4:11 PMstephenniall says:
Omg this is perfect i am gonna do this (have a trackpad in one of my drawers somewhere) and make a rubber pen for it n use it as a sorta mini graphics tablet
Apr 9, 2009. 9:01 PMtwocvbloke says:
Cool, I have a spare touchpad from the old upper casing of my Tosh. Satellite A50 (was going to respray, but got parts from a Tecra A2), and I have always wanted to make use of a touchpad on a PC!!! :D With a little work, you could make a case for the touchpad and buttons using the old laptop's casing, and a bit of wood or a project box... :) I think I shall do this, just to see if I can... :D
Apr 7, 2009. 4:53 PMjstelzer says:
Any pictures of the wires all soldered and whatnot? How did you strip the ribbon wire to connect them?
Apr 7, 2009. 8:15 AMstone3408 says:
Great job! I've been looking for this exact idea for soem time now for a specfic project. Thanks!
Apr 6, 2009. 8:23 PMCameronSS says:
Cool, now I don't feel guilty about not writing it up when I did this.
and I forgot to take pictures
and I mangled the soldering
Apr 6, 2009. 7:23 PMmunchman says:
I love it. And I look forward to seeing the arduino project.
Apr 6, 2009. 6:10 PMmunchman says:
Nice, will do this when I can dig up that old, broken laptop. Very Cool.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:cheft
