Introduction: Turn a Video Into a Gif
You will need:
- Photoshop
- Quicktime
- An internet browser
Step 1: Getting a Video Clip.
For my clip I will be using footage of my co-worker, Gary. He is an excellent dancer and has consented to be featured in this Instructable. I used my video-camera to record Gary dancing, and then opened the clip in Quicktime.
It is important to use a relatively short clip for this, you want to keep your file-sizes down. I cut down my original clip of 20 or so seconds down to 2 seconds. That's about 60ish frames of video.
An easy way to shorten videos in Quicktime is to use the Trim command. (Command + T, or Edit>Trim)
After the video has been trimmed, it is time to export it. (Shift + Command + S, or File>Export)
I use the 480p dedicated export settings, and make sure it saves as a .MOV file.
Step 2: Importing Video to Photoshop
In Adobe Photoshop (I'm using CS5), you are give the option to Import video. (File>Import>Video Frames to Layers)
When in the dialogue box, I selected the checkbox to limit the video to every 2 frames, so that I wouldn't have too many frames beefing up my file-size.
After the video was imported, I had 37 frames, or 37 layers to work with. That's pretty good.
Remember, I had started with two seconds of video, which at 29.97 frames per second should yield about 60 frames. In an effort to keep my file size small, I limited Photoshop to only import every other frame.
Step 3: Image Settings
To optimize my animation for the web it is a good idea to reduce the image quality. I started by playing with the Image Size Settings (Option + Command +I, or Image>Image Size)
I changed the animations width to 500 pixels. I have found that this a pretty internet friendly size.
Step 4: Time Settings
The default amount of time for each frame to show is .03 seconds, but I wanted to make this gif comedically faster. From the Animation Bar, I selected all of the frames. (If you don't see the Animation Bar go to Window>Animation, to toggle it on)
With all the frames selected, I clicked on the downward pointing arrow next to the time increment on the frame, and selected .01 second.
Step 5: Exporting
To export the Gif so that it can be uploaded to the interwebz, I went to File>Save for Web & Devices, or Option + Shift + Command + S.
This brings up another dialog box that you are able to manipulate your file-size from. It is best to get the image under 1MB, if you can.
Please see my image notes for specific instructions.
Step 6: Play!
Play around with it, isolate your favorite frames and create goofy looping gifs. I
For more great Gif possibilities Check out these Instructables:
How to Create Animated Gifs About Pizza
Make an Animated Gif
Make A Wiggle Gif
Thanks! I will award a few 3 Month Pro Memberhips to the first five posters that turn a movie clip into a gif :)
