Background:
We have a Home Theater PC (HTPC) in our living room that tucks neatly out of sight in a corner beside our entertainment unit. The location makes the PC very unobtrusive and even though the tower puts out a normal amount of noise it's barely noticeable. The problem however is the location makes it difficult to access the internal DVD drive to play movies or perform any typical DVD-RW functions. Also there are a number of devices that I have connected to the HTPC which are starting to look a little goofy in and around our entertainment unit (USB Remote IR receiver, USB/firewire hub, External Hard disk, joystick, Wireless keyboard/mouse receiver.) Meanwhile our stand alone DVD player sits unused in a prime easy to reach location (the HTPC has kind of made the DVD player redundant.) This gave me the idea to use an unwanted DVD player as an enclosure for many of those devices.
Remove these ads by
Signing UpStep 1Find a DVD Player to mod
If you are not just using the player at hand like me then you will probably want to find a full height DVD player with a USB port in front. Many DVD players have a low profile form factor that would not accommodate a normal internal PC DVD drive. You could use a slim DVD drive that is popular in many HTPC cases but these are quite a bit more expensive than your everyday internal drive. Ideally the player will also have a power supply that isn't integrated into the main circuit board of the player and uses a molex connector.
One more consideration is the front DVD tray cover. The Digix unit that I am using has a spring loaded door to cover the dvd tray when closed. If the DVD player you are considering has a front cover that is fixed on the end of the drive tray itself ,and sits flush with the front of the player, then you will need to mount the internal drive much more precisely and find a way to mount the cover on the end of the internal IDE DVD drive tray - probably with an extender of some kind.
mines the harmony 300
first sorry about my english (i´m spanish)
one question, i have a working dvd player, but it have problems with the player tray
Will be posible to substitute the player by another one or a hard disc I have arround?
I think would be problems about drivers or something, isn´t it?
the problem with it, is that the tray is not coming properly, but when dvd inside works good
i have others and i dont need it, i wanted to do somethig DIY with it
thanks, good instructable
and i will reply as fast as possible.
i will expecting for you
i din´t think about this, but i will try to find the hole, it isn´t a PC DVD it´s an home DVD
but this DVD isn´t in use, we have anothers
Do you know if I would convert this to an hard disc player?
some drivers problems?
thanks from spain
Great Instructable!
I am going to try and add a small laptop HDD for programming and storage and a TV card.
The flexibility of a PVR in a very small package.
Wish me luck!
If this one burns out I am going for a flat.
