Turn a cleaning sponge into a stunning Magic Trick!
 by Win Guy
Featured
Step 5: Making More Sponge Balls
 Cut three more foam squares that are the same size as the inside-out ball. Cut these into balls as well. Once again, they just have to have the general shape, not necessarily perfect. This trick works with two or three balls, so depending on the size of your hand, you can make however many that suits you.
 Turn the large sponge ball right-side-out again and stuff the other balls into it. Make sure they fit OK - Too lumpy, the audience will suspect something. Too loose, the sponge balls might fall out of the big one.
That's all there is to it - In the next step I will tell you How To Perform This Trick!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
