After some searching, I realized that they were very hard to come by. So I purchased a 45 degree erect-image diagonal and used some old telescope eyepieces and never got it to work: it wouldn't focus.
Then, just before an upcoming trip to Yellowstone, I realized the problem. I needed a Barlow lens in front to shift the focal point back far enough to accommodate the extra length.
Thus, my original project was reborn.
Here is a picture of the completed spotting scope.
Remove these ads by
Signing UpStep 1Gather the stuff (spend the cash)
1) Silicone glue (or any sturdy glue or epoxy). I used silicone because it can be undone to some degree.
2) A telescope eyepiece with a 1.25" barrel (the most common standard). I use a 25mm Celestron Plossl for wide views, and a 10mm Celestron Plossl for high power. (~$50 each)
3) A 45 deg erect image diagonal with a 1.25" barrel (for a spotting scope) OR a 90 degree diagonal with a 1.25" barrel (for a telescope). The barrel needs to be threaded on the inside. Diagonal barrels are often threaded inside to accept filters. I bought my 45deg one from Orion (~$45).
4) A 1.25" 2x Barlow. The lens element holder needs to be unscrewable from the barrel, and the threads need to match the diagonal. Mine did. It is a bottom-of-the-line Celestron ($40)
5) A telephoto lens. There needs to be room to shove the 1.25" barrel of the diagonal about 1" into the backside of the lens. (Some zoom lenses have lens elements right near the opening, which is true of my Canon 85mm to 200mm lens and you'll have to figure out how to get that to work). I'm using a Canon 100-400mm IS zoom lens. (Lots of $$)
6) A lens cap for the back end of the zoom lens (the side that connects to the camera).
7) A 1.25" hole saw. (~$8)
Let me know if you get it working. I'd be interested to see your solution.
http://photo.net/nikon-camera-forum/00HfRR
Enjoy.
- DC
Wow, that's pretty cool. Nice work.
Your link is broken and I couldn't find any erecting eyepieces available in the US anymore, but some of your UK links are still good.
There are two advantages to the way I did it. First, on a spotting scope, it's nice to have a 45 degree prism, so it's a little more comfortable, or you don't have to raise your tripod so high. I'm 6' tall but my tripod isn't.
Second, it is nice to be able to use a few different eyepieces depending on how far I want to look or how wide I need my field of view to be. I can even use my zoom eyepiece (when I buy one, its on my list!).
I had all the other components already, so I only needed the diagonal, so the total cost was not so important for me.
Thanks for the comments.
Nice!
But why would I want to turn an expensive telelens into a scope?
If you're headed to Australia, you can take pictures of the wallabies and then check out the tarantula nebula that night!
