iImage Information
Okay, so in this instructable we will be turning an Eyetoy into a webcam for Windows Vista. If I find any drivers for Windows 7 and XP I will update this post, however I have heard that the Vista driver is compatible with XP systems. Essencially what we will be doing is installinga new driver, if you don't know what that is I will explain. A driver basically allows your computer to communitcate with other software. They eyetoy is missing a driver, when plugged in your computer will recognize that it is a picture/video device but not that it is a webcam, you need to install a driver that will allow your computer to recognize it as a webcam and use it as one.
This instructable should cost you no money, assuming that you already have an eyetoy. The driver download is free.
Step 1Step 1: Designating your Model
iImage Information
The first thing you want to do is check out what model you have. If you have one of the older ones it should be a logitech, if you have the newer silver one it should be a namtai. You can also check this by checking your device manager via the control panel, it should designate it as either a logitech or namtai. Next what you want to do is go to this website:
http://search.4shared.com/q/1/eyetoy
This is the result of searching "eyetoy" on
www.4shared.com
Select one of the two choices as shown in the picture below, choosing either the Namtai or Logitech version of the driver. Also make sure you are selecting an option with the author by the name of Thomas Dobson.
