3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn an Old Mac Into a Home File Server!
If you're a devoted Mac user like me, chances are, you'll have an old Mac sitting around somewhere, collecting dust. Don't give it away or send it off to be killed, repurpose it for use as a home file server! With simple configuration, you will be able to access its files wirelessly, from anywhere within your wireless network. Stream music, movies, and videos! Save files without wasting valuable hard drive space on your primary computer! The possibilities are (almost) endless! All you need is a Mac running OS X with an internet connection, so let's start!
Step 1The Computer
The Computer
To get your file server up and running, you only need two things: a Mac running OS X and an Ethernet Jack or AirPort card. Because the original AirPort card was releases in 1999, computers produced before then (like the Power Macintosh G3 I am using) will not support wireless internet connection. To remedy this, you will need an Ethernet jack somewhere in your house, and a cable to connect it to your spare computer.
Update 3-29: The "Ye olde I-don't-know-what" port is actually an ADB port.
30 comments
Jan 23, 2012. 11:33 PMdylanm312 says:
Is there a way to host the ftp server on a Mac BUT access it from BOTH a Windows computer and a Mac computer?
Sep 25, 2011. 10:30 AMuberdum05 says:
Do any of you know how the old G3 connects to a monitor as when I had a look at one at a car boot sale, it had no apparent VGA / DVI connector?
Dec 6, 2010. 4:31 PMZephyr Wind says:
The 3g was the coolest thing back then... Good times
Oct 3, 2010. 10:15 AMkuhnkat says:
Use 1394 to daisy chain modern SATA drives to your G3!! I have an old dual 450mhz G4 and the FarWar works great!! I use the internal 128GB IDE's for the OS's. Trey booted to 10.4.11, 10.5.6, and 10.4 Server for fun!! Getting 10.5 on it required a ROM hack I found on the web to fool the install into thinking it was OK. The duals make it OK for most things and great as a file server!!
I also got an old external TV box for it that works well. No HD though. I use it to record from Cable/Satellite/Digital Box/DVD/LD. There are a number of PCI WiFi adapters that work with Mac and PC also and it makes it quite convenient to place the box out of the way. With the Mac remote access software you don't even need local monitor, keyboard, or mouse unless you are having problems or installing the OS. Then there are the Unix/Linux remote management/access tools...
Jun 5, 2010. 10:43 AMsidthecat says:
I forgot to add that I'm also connected up to a Belkin Router so I can run it with or without wires. Long story - I'm thinking that I can just connect the G4 to the router, but that seems somehow too easy. Does the Collective Mind have any advice?
Jun 5, 2010. 10:38 AMsidthecat says:
I have a G4 and I want to repurpose it as an FTP server. The rest of my system runs on Win 7 and I have a copy of Ubuntu server. Am I overthinking this, or is there a simpler way to get them to play nicely together?
Mar 29, 2009. 3:04 PMurbanracer34 says:
The "ye-old i don't know what" is a ADB port
more info http://en.wikipedia.org/wiki/Apple_Desktop_Bus
Oct 20, 2009. 5:27 PMmr_novack says:
You say it was top of the line ins 1998, but the G3 B&W didnt came out till 1999. WTF TIME PARADOX
Mar 30, 2010. 12:49 AMFieldownage says:
 You nailed it! Besides why would Apple employees wait a year to use the "new" Mac? ;)
Nov 10, 2009. 8:04 PMlunchboxslayer27 says:
=O
Mar 11, 2010. 1:58 PMIcedvovo says:
 A standard off-the-shelf Wireless Access Point or an Airport Base Station will allow just about any Mac with an Ethernet port  to connect wirelessly to an existing network.
In most cases this is a lot easier, cheaper and more compatible than an opting for an internal Airport card. This solution will work with some REALLY ancient Macs.
Mar 11, 2010. 9:41 AMdanton721 says:
copy the mac OS X CDs for me???
I had downloaded,but,it impossible to burn they!
Mar 7, 2010. 6:10 PMbroken_to_fix says:
 nice dude!
Nov 23, 2009. 7:16 PMtompaige says:
the adb portis an Ethernet port ok
Sep 25, 2009. 6:45 PMMACKattacksnipe says:
i got 5 free 1TB hdd im going to custom build this but with windows ill make an instructable for the windows version
Sep 17, 2009. 7:16 AMindromac says:
I have a g4 800mhz as the oldmummy, I there any way to connect and watch tv form this machine (without a tv card, of course), Is there a way to connect the some device that I can build? thanks
Apr 21, 2009. 10:21 AMServer_Rack_Guy says:
So I have an Apple II and I want to make a server out of it because it is so powerful, what do I do? LOL The Blue and Whites were great in their day weren't they? The Apple computers keep running because they used premium parts in those days; my 8600 is still cranking...SCSI hard drives were the way to go if you could afford them.
Aug 30, 2009. 12:02 AMKasm279 says:
and in todays times they can reach the lofty height of 3 128GB drives (128GB is the IDE hard drive limit till about 2003)
Apr 30, 2009. 4:49 PMfwjs28 says:
WOWZERZ...lol, macs are some pretty powerful beasts....
Aug 8, 2009. 11:37 AMDouglass says:
Can the serve be used to log in with a vista laptop ?
Aug 30, 2009. 12:00 AMKasm279 says:
yes, if you turn on Windows File Sharing, but you can add apf (apple file protocol) to windows
Jul 29, 2009. 12:12 AMKasm279 says:
What is the clock speed?
also, what OS?
May 27, 2009. 5:17 AMthepaul1993 says:
this is great, but to run a server to only have 12gb of space, it will be cheaper in the long run to get an external hard drive.
May 26, 2009. 5:22 PM7xsevenx7 says:
I have only a mac g3 can i do this with a pc?
May 1, 2009. 6:02 PMdombeef says:
YAY!!!! A "Devoted" Mac user!!!!I have like 8 old computers
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:Radioactive_Legos
