Here's a list of parts you'll need to get started:
- exercise bike, with cast iron flywheel or rubber tire type
- DC motor or generator with magnets, 12Vdc or 120Vdc recommended
- 1/2" plywood, 3/4" will also work
- 6' - 2"x 4" pine lumber
- 4' link belt (or fan belt)
- 1/4" Lag bolts
- assorted screws
- 3/4" water pipe and end caps
- screw band
- wire DC volt meter
- DC amp meter
- 14 ga. wire
- 2' of 1-1/2" PVC pipe
- 1-1/2" sheave (pulley)
Tools you'll need:
- jig saw
- hand saw or chop saw
- router (optional)
- drill and bits
- hacksaw
- file
- wire cutters and strippers
- screw driver
- socket set and ratchet
- carbide cutter
- vise grips
Remove these ads by
Signing UpStep 1Prepping the exercise bike
Start prepping you exercise bike for conversion by removing unnecessary equipment. Most exercise bikes have either brake pads or a web strap that rides on the perimeter of the flywheel. This one has a watt meter hooked to the drag brakes.
On this model, you'll also need to remove the rubber banding from the perimeter of the flywheel.
You can buy a stepper motor from $35, or visit radio shack for a small toy motor more appropriately sized for one person, rather than 200 horses.
dc generators achieve from 50-80% efficiency.
the rotational speed of the alternator is not important as this instructable already uses a pulley and belt to turn the DC motor(generator) faster than the crank speed of the 'bike'.
being used as a human powered generator seems a little harsh....
also, time travel has most definitely occurred.
Have you considered or experimented with a flywheel in the loop?
I'm a cyclist and we're used to taking advantage of the 'freewheel' effect a rolling momentum brings about.
I've seen a four person static bike that powered a small stage at a festival - that was more than a decade ago - and I still often wonder if this idea is worth merit...
Obviously gears would enable a start up - perhaps even for a very heavy flywheel spinning eventually at quite a clip!.. good bearings being a must.
Basically any experience on a bike and you'll remember - that flush of energy one feels at the mere hint of 'powering off' as it were.
Must say - apart from this fine example and others like it, I've never liked exercise bikes - monotony!.. hence the above....
Any thoughts?
You are helping the planet one person makes a difference!
