http://senseless.livejournal.com/152881.html
Remove these ads by
Signing UpStep 1Make a big Box.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Next I'm going to try using two or three 40 gallon well tanks buried in the sand. I'm not getting as much heat transfer as I'd like with 300 feet of pipe, the water passes through it too quickly.
I had originally planned on pipes like you mention inside say a ten inch pipe filled with sand but getting the sand in there would have been difficult.
Carrying 3 tons of sand up there in five gallon pails was work enough LOL.
They use LEAD solder to build them since there not for human consumption. Please be careful!!!!!
However, TDRAGO, it's a great thought but the Lead used to solder those together or lead that maybe in the material itself just isn't worth the health risk…
Still a good thought.
Regular trusses would not support this weight and it would fall though the attic floor...
The house isn't built like most stick houses, I went out of my weigh (no pun intended) to make it take a very high windload and can sleep right through a tropical storm without a creak.
It's like a bunch of shipping containers tied together to form the rooms on the main floor.
I forget the load a standard truss can support but it is well below the mass I have sitting up there.
Overall I used 7 bunks of plywood, bundles, and about 50 cases of liquid nails, then covered that with sheet rock so it appears like a normal wall inside and a side effect is that inside the house is extremely quiet even though I live 500 feet from an evacuation route, US 331.
You can hear the traffic in my vids done outside but not the ones done inside.
For a stick framed house it is very very stout.
These are meant to contain hot water and only release water when the temperature of the cap is exceeded.
They could even be directly attached to the undersurface of the roof or elevated near the roof for maximum heat transfer. You could feed one radiator into a second or more radiators thereby further heating the already heated water... Might get TOO hot!
You could even get fancy and add a thermostatically controlled fan. There is a commercial product along these lines. See: http://www.solarattic.com/pcs1.htm
It is called PEX pipes, which it is little expensive, kink easily ( If you aren't careful ), but good thing about it is they don't condense and don't corrodes.
This is the mandatory new code in Canada on the new building now. There is too many problems related to copper pipes in old and middle aged homes.
We have PEX pipes in our home, the only we have to use the metal pipes is to lead the outside water system.
Please correct me if I'm wrong, but this is all I can know of. If you wish, check out the hardwares stores.
http://www.plumberscrib.com/Departments/Pex/Pex-Pipe.aspx
