Step 8The End
3 Simple Ways to
Share What You Make
Other ways to share:
Making a Solar Battery Panel without Soldering
by
dkdls09
Solar tracker using an old hard drive
by
scraptopower
Making Solar cells with no soldering points usable
by
EARTHFORSOLAR
green dynamo and solar power supply
by
sapc
PORTABLE SOLAR AC POWER
by
jackson88
DIY Solar panels - air heaters made of pop cans
by
Mladen_solar
Homemade 63 Watt Solar Panel
by
airsofter1
Weekly Project: Go Green GBA--A Solar-Powered Game Boy Advance
by
PSdp
Comments: 73
Rating: 4.3
All Steps Viewing
Next I'm going to try using two or three 40 gallon well tanks buried in the sand. I'm not getting as much heat transfer as I'd like with 300 feet of pipe, the water passes through it too quickly.
I had originally planned on pipes like you mention inside say a ten inch pipe filled with sand but getting the sand in there would have been difficult.
Carrying 3 tons of sand up there in five gallon pails was work enough LOL.
They use LEAD solder to build them since there not for human consumption. Please be careful!!!!!
However, TDRAGO, it's a great thought but the Lead used to solder those together or lead that maybe in the material itself just isn't worth the health risk…
Still a good thought.
These are meant to contain hot water and only release water when the temperature of the cap is exceeded.
They could even be directly attached to the undersurface of the roof or elevated near the roof for maximum heat transfer. You could feed one radiator into a second or more radiators thereby further heating the already heated water... Might get TOO hot!
You could even get fancy and add a thermostatically controlled fan. There is a commercial product along these lines. See: http://www.solarattic.com/pcs1.htm
Ever use a Peltier device?
http://www.ferrotec.com/products/thermal/modules/?_kk=peltier&_kt=21f0c9bc-1382-4cbb-ad01-5773c9e8e9a0&gclid=CMvTzfTUnJACFQUbgQodZl4Qqw
